Datasheet ADA4500-2 (Analog Devices) - 9
Description10 MHz, 14.5 nV/√Hz, Rail-to-Rail I/O, Zero Input Crossover Distortion Amplifier
Pages / Page24 / 9 — Data Sheet. ADA4500-2. TYPICAL PERFORMANCE CHARACTERISTICS. 100. 90 VSY = …
RevisionB
Data Sheet. ADA4500-2. TYPICAL PERFORMANCE CHARACTERISTICS. 100. 90 VSY = 2.7V. 90 VSY = 5.0V. VCM = VSY/2. UNI. R O. NUM
Data Sheet ADA4500-2 TYPICAL PERFORMANCE CHARACTERISTICS 100 90 VSY = 2.7V 90 VSY = 5.0V VCM = VSY/2 UNI R O NUM
TA = 25°C, unless otherwise noted.
100 100 ADA4500-2 ADA4500-2 90 VSY = 2.7V 90 VSY = 5.0V VCM = VSY/2 VCM = VSY/2 80 80 70 S 70 S T T 60 60 UNI UNI F F 50 50 R O R O BE 40 BE 40 NUM 30 NUM 30 20 20 10 10 0 0
2 5
–120 –100 –80 –60 –40 –20 0 20 40 60 80 100 120 –120 –100 –80 –60 –40 –20 0 20 40 60 80 100 120
-00 -00 7 7
VOS (µV)
61
V
61 10
OS (µV)
10 Figure 5. Input Offset Voltage Distribution, VSY = 2.7 V Figure 8. Input Offset Voltage Distribution, VSY = 5.0 V
35 35 ADA4500-2 ADA4500-2 VSY = 2.7V VSY = 5.0V 30 VCM = VSY/2 30 VCM = VSY/2 –40°C ≤ TA ≤ +125°C –40°C ≤ TA ≤ +125°C 25 25 S S T T UNI 20 UNI 20 F F R O R O 15 BE 15 BE NUM NUM 10 10 5 5 0 0 0 1.25 2.50 3.75 5.00 6.25 7.50 8.75
06 03 0
0
TCV
17- 17-
OS (µV/°C)
06
TCV
06 1
OS (µV/°C)
1 Figure 6. Input Offset Voltage Drift Distribution, VSY = 2.7 V Figure 9. Input Offset Voltage Drift Distribution, VSY = 5.0 V
100 100 ADA4500-2 ADA4500-2 80 VSY = 2.7V 80 VSY = 5.0V 60 60 40 40 20 ) 20 V) (µV 0 0 OS OS V V –20 –20 –40 –40 –60 –60 –80 –80 –100 –100
7
–0.2 0.3 0.8 1.3 1.8 2.3 2.8 –0.2 0.8 1.8 2.8 3.8 4.8
04 -00 0 7 7-
V
61
CM (V)
61
VCM (V)
10 10 Figure 7. Input Offset Voltage (VOS) vs. Common-Mode Voltage (VCM), VSY = 2.7 V Figure 10. Input Offset Voltage (VOS) vs. Common-Mode Voltage (VCM), VSY = 5.0 V Rev. B | Page 9 of 24 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS VSY = 2.7 V ELECTRICAL CHARACTERISTICS VSY = 5.0 V ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION RAIL-TO-RAIL OUTPUT RAIL-TO-RAIL INPUT (RRI) ZERO CROSS-OVER DISTORTION OVERLOAD RECOVERY POWER-ON CURRENT PROFILE APPLICATIONS INFORMATION RESISTANCE AND CAPACITANCE SENSOR CIRCUIT ADAPTIVE SINGLE-ENDED-TO-DIFFERENTIAL SIGNAL CONVERTER The Challenge The Solution OUTLINE DIMENSIONS ORDERING GUIDE
