Datasheet AD823A (Analog Devices) - 5
DescriptionWide Supply Dual, 17 MHz, Rail-to-Rail FET Input Amplifier
Pages / Page20 / 5 — Data Sheet. AD823A. ±15 V OPERATION. Table 3. Parameter. Conditions. Min. …
RevisionB
File Format / SizePDF / 521 Kb
Data Sheet. AD823A. ±15 V OPERATION. Table 3. Parameter. Conditions. Min. Typ. Max. Unit
Data Sheet AD823A ±15 V OPERATION Table 3 Parameter Conditions Min Typ Max Unit
TA = 25°C, VS = ±15 V, RL = 2 kΩ to 0 V, unless otherwise noted.
Table 3. Parameter Conditions Min Typ Max Unit
DYNAMIC PERFORMANCE −3 dB Bandwidth G = +1, VOUT ≤ 0.2 V p-p 16.5 19 MHz Full Power Response VOUT = 2 V p-p 5.6 MHz Slew Rate G = −1, VOUT = 10 V step 31 35 V/µs Settling Time To 0.1% G = −1, VOUT = 10 V step 380 ns To 0.01% G = −1, VOUT = 10 V step 510 ns NOISE/DISTORTION PERFORMANCE Input Voltage Noise f = 10 kHz 13 nV/√Hz Input Current Noise f = 1 kHz 1 fA/√Hz Harmonic Distortion (SFDR) VOUT = 10 V p-p, f = 20 kHz, G = −1, RF = RG = −101 dBc 4 kΩ VOUT = 10 V p-p, f = 20 kHz, G = +1, RL = 600 Ω −89 dBc Crosstalk f = 1 kHz RL = 5 kΩ −123 dB f = 1 MHz RL = 5 kΩ −77 dB DC PERFORMANCE Initial Offset 0.8 3.5 mV Maximum Offset over Temperature 1.0 5 mV Offset Drift 1 µV/°C Input Bias Current VCM = 0 V 1.3 25 pA VCM = −10 V 3.5 pA At TMAX VCM = 0 V 55 95 pA Input Offset Current 1.3 20 pA At TMAX 9.5 pA Open-Loop Gain VOUT = +10 V to −10 V, RL = 2 kΩ 100 450 V/mV TMIN to TMAX 80 V/mV INPUT CHARACTERISTICS Input Common-Mode Voltage Range −15.2 to +13 −15.2 to +13.8 V Input Resistance 1013 Ω Input Capacitance Differential Mode 0.6 pF Common Mode 1.3 pF Common-Mode Rejection Ratio VCM = −15 V to +13 V 70 90 dB OUTPUT CHARACTERISTICS Output Voltage Swing IL = ±100 µA −14.9 to +14.96 V IL = ±2 mA −14.97 to +14.96 V IL = ±10 mA −14.91 to +14.89 V Linear Output Current VOUT = −14.5 V to +14.5 V 44 mA Short-Circuit Current Sourcing to 0 V 78 mA Sinking to 0 V 124 mA Capacitive Load Drive G = +1 500 pF POWER SUPPLY Operating Range 3 36 V Quiescent Current TMIN to TMAX, total 6.3 8.4 mA Power Supply Rejection Ratio VS = 5 V to 15 V, TMIN to TMAX 70 94 dB Rev. B | Page 5 of 20 Document Outline Features Applications General Description Connection Diagram Revision History Specifications 5 V Operation 3.3 V Operation ±15 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Output Impedance Applications Information Input Characteristics Output Characteristics Wideband Photodiode Preamp Active Filter Maximizing Performance Through Proper Layout Outline Dimensions Ordering Guide
