Datasheet ADL8150ACHIP (Analog Devices) - 4
DescriptionGaAs, HBT, MMIC, Low Phase Noise Amplifier, 6 GHz to 14 GHz
Pages / Page14 / 4 — ADL8150ACHIP. Data Sheet. FREQUENCY RANGE: 11 GHz TO 14 GHz. Table 3. …
File Format / SizePDF / 289 Kb
ADL8150ACHIP. Data Sheet. FREQUENCY RANGE: 11 GHz TO 14 GHz. Table 3. Parameter. Min. Typ. Max. Unit. Test Conditions/Comments
ADL8150ACHIP Data Sheet FREQUENCY RANGE: 11 GHz TO 14 GHz Table 3 Parameter Min Typ Max Unit Test Conditions/Comments
TA = 25°C, VCC = 5 V, and ICQ = 76 mA for nominal operation, unless otherwise noted.
Table 3. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 11 14 GHz GAIN 9.5 11.5 dB Gain Flatness ±0.7 dB Gain Variation over Temperature 0.014 dB/°C NOISE FIGURE 4 dB PHASE NOISE −172 dBc/Hz Measurement taken at 10 kHz offset from carrier RETURN LOSS Input 5.5 dB Output 8 dB OUTPUT P1dB 17.5 19.5 dBm PSAT 23 dBm IP3 31 dBm Measurement taken at POUT per tone = 6 dBm SUPPLY ICQ 76 mA Self biased VCC 3 5 6 V Rev. 0 | Page 4 of 14 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Frequency Range: 6 GHz to 7 GHz Frequency Range: 7 GHz to 11 GHz Frequency Range: 11 GHz to 14 GHz Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for ADL8150ACHIP ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Biasing Procedures Handling Precautions Mounting Wire Bonding Assembly and Typical Application Circuit Diagrams Outline Dimensions Ordering Guide
