Datasheet HMC1022ACHIPS (Analog Devices) - 3
DescriptionGaAs, pHEMT, MMIC, 0.25 W Power Amplifier, DC to 48 GHz
Pages / Page17 / 3 — Data Sheet. HMC1022ACHIPS. ELECTRICAL SPECIFICATIONS. DC TO 30 GHz …
File Format / SizePDF / 452 Kb
Data Sheet. HMC1022ACHIPS. ELECTRICAL SPECIFICATIONS. DC TO 30 GHz FREQUENCY RANGE. Table 1. Parameter. Symbol. Min. Typ. Max. Unit
Data Sheet HMC1022ACHIPS ELECTRICAL SPECIFICATIONS DC TO 30 GHz FREQUENCY RANGE Table 1 Parameter Symbol Min Typ Max Unit
TA = 25°C, supply voltage (VDD) = 10 V, gate bias voltage (VGG2) = 4.0 V, and quiescent drain supply current (IDQ) = 150 mA for nominal operation, unless otherwise noted.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE DC 30 GHz GAIN 11.5 dB Gain Flatness ±0.5 dB Gain Variation over Temperature 0.015 dB/°C NOISE FIGURE 4.5 dB RETURN LOSS Input 16 dB Output 20 dB OUTPUT Output Power for 1 dB Compression P1dB 23 25 dBm Saturated Output Power PSAT 26 dBm Output Third-Order Intercept IP3 33 dBm Measurement taken at output power (POUT) per tone = 16 dBm SUPPLY Current IDQ 125 150 mA Adjust the gate bias voltage (VGG1) between −2 V up to 0 V to achieve the IDQ Voltage VDD 9 10 V
30 GHz TO 40 GHz FREQUENCY RANGE
TA = 25°C, VDD = 10 V, VGG2 = 4.0 V, and IDQ = 150 mA for nominal operation, unless otherwise noted.
Table 2. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 30 40 GHz GAIN 11.5 dB Gain Flatness ±0.5 dB Gain Variation over Temperature 0.019 dB/°C NOISE FIGURE 5.5 dB RETURN LOSS Input 22 dB Output 12 dB OUTPUT Output Power for 1 dB Compression P1dB 19 21 dBm Saturated Output Power PSAT 24.5 dBm Output Third-Order Intercept IP3 29 dBm Measurement taken at POUT per tone = 16 dBm SUPPLY Current IDQ 125 150 mA Adjust the VGG1 between −2 V up to 0 V to achieve the IDQ Voltage VDD 9 10 V Rev. 0 | Page 3 of 17 Document Outline Features Applications Functional Block Diagram General Description Revision History Electrical Specifications DC to 30 GHz Frequency Range 30 GHz to 40 GHz Frequency Range 40 GHz to 48 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Biasing Procedures Mounting and Bonding Techniques for Millimeterwave GaAs MMICs Handling Precautions Mounting Wire Bonding Outline Dimensions Ordering Guide
