Datasheet HMC7543 (Analog Devices) - 8
Description | 71 GHz to 76 GHz, E-Band Power Amplifier With Power Detector |
Pages / Page | 16 / 8 — HMC7543. Data Sheet. IDD = 350mA. A = –55°C. DD = 400mA. Bm). DD = 450mA. … |
Revision | A |
File Format / Size | PDF / 247 Kb |
HMC7543. Data Sheet. IDD = 350mA. A = –55°C. DD = 400mA. Bm). DD = 450mA. B (. TA = +25°C. A = +85°C. 71.0. 71.5. 72.0. 72.5. 73.0. 73.5. 74.0. 74.5. 75.0
HMC7543 Data Sheet 30 30 29 29 28 28 IDD = 350mA 27 T 27 I A = –55°C DD = 400mA Bm) Bm) I d d DD = 450mA 26 26 B ( TA = +25°C B ( 1d 25 1d 25 P P T UT A = +85°C UT P 24 P 24 UT UT O 23 O 23 22 22 21
015
21
018 13423-
20
13423-
20 71.0 71.5 72.0 72.5 73.0 73.5 74.0 74.5 75.0 75.5 76.0 71.0 71.5 72.0 72.5 73.0 73.5 74.0 74.5 75.0 75.5 76.0 FREQUENCY (GHz) FREQUENCY (GHz)
Figure 15. Output P1dB vs. Frequency at Various Temperatures, Figure 18. Output P1dB vs. Frequency at Various Drain Currents (IDD) Drain Current (IDD) = 450 mA
30 30 29 29 IDD = 350mA 28 28 IDD = 400mA TA = –55°C IDD = 450mA 27 27 TA = +25°C 26 26 Bm) Bm) d TA = +85°C d ( 25 ( 25 T T A A S S P 24 P 24 23 23 22 22 21
016
21
019 13423-
20
13423-
Figure 16. PSAT vs. Frequency at Various Temperatures, Figure 19. PSAT vs. Frequency at Various Drain Currents (IDD) Drain Current (IDD) = 450 mA
35 35 34 34 IDD = 350mA 33 33 IDD = 400mA I T DD = 450mA A = +25°C 32 32 T Bm) A = –55°C Bm) d 31 d 31 3 ( 3 ( P P I 30 I 30 UT T UT P A = +85°C 29 P 29 UT UT O O 28 28 27 27 26
017
26
020 13423-
25
13423-
25 71.0 71.5 72.0 72.5 73.0 73.5 74.0 74.5 75.0 75.5 76.0 71.0 71.5 72.0 72.5 73.0 73.5 74.0 74.5 75.0 75.5 76.0 FREQUENCY (GHz) FREQUENCY (GHz)
Figure 17. Output IP3 (OIP3) vs. Frequency at Various Temperatures, Figure 20. Output IP3 (OIP3) vs. Frequency at Various Drain Currents (IDD), Drain Current (IDD) = 450 mA, POUT/Tone = 12 dBm POUT/Tone = 12 dBm Rev. A | Page 8 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS HANDLING PRECAUTIONS Storage Cleanliness Static Sensitivity Transients General Handling MOUNTING Eutectic Die Attach Epoxy Die Attach WIRE BONDING OUTLINE DIMENSIONS ORDERING GUIDE
