Datasheet HMC7543 (Analog Devices) - 9
Description71 GHz to 76 GHz, E-Band Power Amplifier With Power Detector
Pages / Page16 / 9 — Data Sheet. HMC7543. 16dBm. IDD = 350mA. IDD = 400mA. 14dBm. IDD = 450mA. …
RevisionA
File Format / SizePDF / 247 Kb
Data Sheet. HMC7543. 16dBm. IDD = 350mA. IDD = 400mA. 14dBm. IDD = 450mA. Bm). 12dBm. 3 (. 71.0. 71.5. 72.0. 72.5. 73.0. 73.5. 74.0. 74.5. 75.0. 75.5. 76.0
Data Sheet HMC7543 16dBm IDD = 350mA IDD = 400mA 14dBm IDD = 450mA Bm) 12dBm 3 ( 71.0 71.5 72.0 72.5 73.0 73.5 74.0 74.5 75.0 75.5 76.0
Data Sheet HMC7543 35 35 34 34 16dBm 33 33 IDD = 350mA IDD = 400mA 14dBm 32 32 IDD = 450mA Bm) Bm) d 31 12dBm d 31 3 ( 3 ( P P I 30 I 30 UT UT P 29 P 29 UT UT O O 28 28 27 27 26
021
26
024 13423-
25
13423-
25 71.0 71.5 72.0 72.5 73.0 73.5 74.0 74.5 75.0 75.5 76.0 8 9 10 11 12 13 14 15 16 FREQUENCY (GHz) POUT/TONE (dBm)
Figure 21. Output IP3 (OIP3) vs. Frequency at Various POUT per Tone Values, Figure 24. Output IP3 (OIP3) vs. POUT per Tone at Various Drain Currents (IDD), Drain Current (IDD) = 450 mA RF = 71 GHz
35 35 34 34 33 IDD = 350mA 33 IDD = 350mA IDD = 400mA IDD = 400mA 32 IDD = 450mA 32 IDD = 450mA Bm) d 31 Bm) d 31 3 ( P 3 ( I 30 P I 30 UT P UT 29 P 29 UT UT O 28 O 28 27 27 26
022
26
025 13423-
25
13423-
25 8 9 10 11 12 13 14 15 16 8 9 10 11 12 13 14 15 16 POUT/TONE (dBm) POUT/TONE (dBm)
Figure 22. Output IP3 (OIP3) vs. POUT per Tone at Various Drain Currents (IDD), Figure 25. Output IP3 (OIP3) vs. POUT per Tone at Various Drain Currents (IDD), RF = 73.5 GHz RF = 76 GHz
30 30 Bm) 29 29 d Bm) ( d T ( A 28 T 28 S A S ), P 27 ), P 27 m PSAT (dBm) m PSAT (dBm) dB ( 26 dB OUTPUT P1dB (dBm) ( 26 dB OUTPUT P1dB (dBm) 1 dB 25 1 25 T P T P U 24 U 24 TP TP 23 23 ), OU ), OU dB 22 ( dB 22 ( GAIN (dB) IN IN GAIN (dB) 21
023
21 GA
026
GA
13423-
20
13423-
20 350 400 450 350 400 450 IDD (mA) IDD (mA)
Figure 23. Gain, Output P1dB, and PSAT vs. Drain Current (IDD), RF = 71 GHz Figure 26. Gain, Output P1dB, and PSAT vs. Drain Current (IDD), RF = 73.5 GHz Rev. A | Page 9 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICS HANDLING PRECAUTIONS Storage Cleanliness Static Sensitivity Transients General Handling MOUNTING Eutectic Die Attach Epoxy Die Attach WIRE BONDING OUTLINE DIMENSIONS ORDERING GUIDE
