Datasheet HMC635LC4 (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC DRIVER AMPLIFIER, 18 -40 GHz
Pages / Page6 / 3 — HMC635LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 18 - 40 GHz. Power …
HMC635LC4. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 18 - 40 GHz. Power Compression @ 30 GHz [1]. Power Compression @ 40 GHz [1]
HMC635LC4 GaAs PHEMT MMIC DRIVER AMPLIFIER, 18 - 40 GHz Power Compression @ 30 GHz [1] Power Compression @ 40 GHz [1]
HMC635LC4
v02.0218
30 30 T ) Pout (dBm) Pout (dBm) % % 25 Gain (dB) 25 Gain (dB) ( M E PAE (%) E PAE (%) A A ), P 20 ), P 20 B B d d ( IN IN 15 15 K - S A A ), G ), G C m m 10 10 B B d d t ( t ( u u o o LO 5 5 P P 0 0 -15 -10 -5 0 5 10 -15 -10 -5 0 5 10 IN B INPUT POWER (dBm) INPUT POWER (dBm) A
Output IP3 vs. Temperature Noise Figure vs. Temperature [1]
R & G 40 15 E 36 +25 C IV 12 ) -40 C B R d 32 +25 C ( ) -40 C E m 9 R U (dB 28 IG 3 F IP E 6 IS S - D 24 O N R 3 20 IE 16 0 16 21 26 31 36 41 16 21 26 31 36 41 LIF FREQUENCY (GHz) FREQUENCY (GHz) P M
Gain & Power vs.
A
Supply Voltage @ 30 GHz [1] Reverse Isolation vs. Temperature
26 0 ) m B -10 d 24 t ( a s ) -20 +25C - 40C B ), P d ( m 22 Gain B N -30 P1dB d IO ( Psat T B A d L -40 1 20 O ), P IS B -50 d ( 18 IN A -60 G 16 -70 4.5 4.7 4.9 5.1 5.3 5.5 16 21 26 31 36 41 Vdd (V) FREQUENCY (GHz) [1] Board loss subtracted out for gain, power and noise figure measurements. For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
3
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Reverse Isolation vs. Temperature Gain & Power vs. Supply Voltage @ 30 GHz Noise Figure vs. Temperature Power Compression @ 40 GHz Power Compression @ 30 GHz Psat vs. Temperature P1dB vs. Temperature Output Return Loss vs. Temperature Input Return Loss vs. Temperature Gain vs. Temperature Broadband Gain & Return Loss Output IP3 vs. Temperature Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Pin Descriptions Application Circuit Evaluation PCB List of Materials
