Datasheet HMC634 (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC DRIVER AMPLIFIER, 5 -20 GHz
Pages / Page8 / 3 — HMC634. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5 - 20 GHz. Power Compression …
File Format / SizePDF / 410 Kb
HMC634. GaAs PHEMT MMIC DRIVER. AMPLIFIER, 5 - 20 GHz. Power Compression @ 12.5 GHz. Power Compression @ 20 GHz
HMC634 GaAs PHEMT MMIC DRIVER AMPLIFIER, 5 - 20 GHz Power Compression @ 12.5 GHz Power Compression @ 20 GHz
HMC634
v01.0308
2 30 30 27 27 24 24 21 21 IP 18 18 H 15 15 12 12 9 9 - C Pout (dBm) Gain (dB) 6 6 S PAE (%) Pout (dBm) Pout (dBm), GAIN (dB), PAE (%) Pout (dBm), GAIN (dB), PAE (%) Gain (dB) 3 3 PAE (%) R 0 0 IE -10 -8 -6 -4 -2 0 2 4 6 -10 -8 -6 -4 -2 0 2 4 6 INPUT POWER (dBm) INPUT POWER (dBm) IF L P M
Output IP3 vs. Temperature Noise Figure vs. Temperature
36 15 K A 34 32 12 OC 30 28 9 26 GURE (dB) BL IP3 (dBm) 24 +25 C 6 SE FI +85 C IN 22 -55 C NOI +25 C A 20 3 +85 C -55 C 18 16 0 & G 3 6 9 12 15 18 21 24 2 4 6 8 10 12 14 16 18 20 22 24 FREQUENCY (GHz) FREQUENCY (GHz) R E IV
Gain & Power vs.
R
Supply Voltage @ 12.5 GHz Reverse Isolation vs. Temperature
D 26 0 -10 25 -20 +25 C +85 C -30 -55 C 24 -40 Bm), Psat (dBm) 23 -50 -60 22 ISOLATION (dB) -70 Gain P1dB Psat -80 21 GAIN (dB), P1dB (d -90 20 -100 4.5 4.6 4.7 4.8 4.9 5 5.1 5.2 5.3 5.4 5.5 2 4 6 8 10 12 14 16 18 20 22 24 Vdd (V) FREQUENCY (GHz) Information furnis F he o d r pri by An ce, de alog Devic leiv s ies ry be , a lievend to pla d to be accurce o ate an rd der relia s bl , pl e. Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 rights of third parties that may result from its use. Specifications subject to change without notice. No
2 - 52
20 Alpha Road, Chelmsford, MA 01824 Phone: 978 Pho - n 25 e: 7 0- 81 33 2 4 9- 3 F 470 ax: 978 0 • Order o - n25 lin 0- e a 3 t 373 license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hit A tpite.co plicatio m n Support: Phone: 1-800-ANALOG-D
