Datasheet HMC450QS16G, 450QS16GE (Analog Devices)
DescriptionGaAs InGaP HBT MMIC POWER AMPLIFIER, 0.8 - 1.0 GHz
Pages / Page8 / 1 — HMC450QS16G / 450QS16GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 0.8 - 1.0 …
File Format / SizePDF / 417 Kb
HMC450QS16G / 450QS16GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 0.8 - 1.0 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC450QS16G, 450QS16GE Analog Devices
v02.0406
GaAs InGaP HBT MMIC POWER AMPLIFIER, 0.8 - 1.0 GHz Typical Applications Features
The HMC450QS16G / HMC450QS16GE is ideal for Gain: 26 dB power and driver amplifi er applications: 32% PAE @ 28.5 dBm Output Power • GSM, GPRS, & Edge +40 dBm Output IP3 • CDMA & WCDMA Integrated Power Control (Vpd) • Base Stations & Repeaters 11 Included in the HMC-DK002 Designer’s Kit
T The HMC450QS16G & HMC450QS16GE are high efficiency GaAs InGaP HBT Medium Power MMIC amplifi ers operating between 800 and 1000 MHz. The - SM amplifi er is packaged in a low cost, surface mount S 16 lead package and offers the same pinout and R functionality as the higher band HMC413QS16G 1.6- IE 2.3 GHz PA. With a minimum of external components, IF the amplifi er provides 26 dB of gain, +40 dBm OIP3 L and +28.5 dBm of saturated power from a +5V supply P voltage. The integrated power control (Vpd) can be used M for full power down or RF output power/current control. The combination of high gain and high output IP3 make the HMC450QS16G & HMC450QS16GE ideal R A E linear drivers for Cellular, PCS & 3G applications. W O & P
Electrical Specifi cations, T = +25° C, Vs = +5V, Vpd = +4V [1] A
R A Parameter Min. Typ. Max. Units E Frequency Range 0.8 - 1.0 GHz Gain 23 26 dB IN L Gain Variation Over Temperature 0.015 0.025 dB/°C Input Return Loss 17 dB Output Return Loss 13 dB Output Power for 1 dB Compression (P1dB) 23 26 dBm Saturated Output Power (Psat) 28.5 dBm Output Third Order Intercept (IP3) [2] 37 40 dBm Noise Figure 8 dB Supply Current (Icq) 310 mA Control Current (Ipd) 12 mA Switching Speed tON, tOFF 10 ns [1] Specifi cations and data refl ect HMC450QS16G measured using the application circuit found herein. Contact the HMC Applications Group for assistance in optimizing performance for your application. [2] Two-tone output power of +15 dBm per tone, 1 MHz spacing. Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
11 - 114
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
