Datasheet HMC465 (Analog Devices) - 7
DescriptionGaAs pHEMT MMIC MODULATOR DRIVER AMPLIFIER, DC - 20 GHz
Pages / Page8 / 7 — HMC465. GaAs pHEMT MMIC MODULATOR. DRIVER AMPLIFIER, DC - 20 GHz. Device …
File Format / SizePDF / 472 Kb
HMC465. GaAs pHEMT MMIC MODULATOR. DRIVER AMPLIFIER, DC - 20 GHz. Device Operation. Device Power Down Instructions
HMC465 GaAs pHEMT MMIC MODULATOR DRIVER AMPLIFIER, DC - 20 GHz Device Operation Device Power Down Instructions
HMC465
v09.0114
These devices are susceptible to damage from Electrostatic Discharge. Proper precautions should be observed during handling, assembly and test. IP H The input to this device should be AC-coupled. To provide the typical 8Vp-p output voltage swing, a 1.2Vp-p AC-coupled input voltage swing is required. S - C 1. Ground the device K C 2. Set Vgg1 to -2V (no drain current) 3. Set Vgg2 to +1.5V (no drain current) LO 4. Set Vdd to +8V (no drain current) 5. Adjust Vgg1 for Idd = 160mA (Vgg1 may be varied between -2V and 0V to set Idd to 160mA) IN B 6. Apply RF signal to input. A
S & G 1. Remove RF signal from input R 2. Remove Vdd E 3. Remove Vgg2 IV 4. Remove Vgg1 R - D S R IE LIF P M A Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
7
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
