Datasheet HMC407MS8G, 407MS8GE (Analog Devices) - 3
DescriptionGaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 7 GHz
Pages / Page6 / 3 — HMC407MS8G / 407MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 5 - 7 GHz. …
File Format / SizePDF / 921 Kb
HMC407MS8G / 407MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 5 - 7 GHz. Power Compression @ 5.8 GHz. Output IP3 vs. Temperature
HMC407MS8G / 407MS8GE GaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 7 GHz Power Compression @ 5.8 GHz Output IP3 vs Temperature
v04.1019
GaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 7 GHz Power Compression @ 5.8 GHz Output IP3 vs. Temperature
30 44 (%) 25 39 PAE 20 34 ) (dB), 15 (dBm 29 9 GAIN IP3 +25 C 10 24 +85 C (dBm), -40 C Pout (dBm) 5 Gain (dB) Pout 19 PAE (%) T 0 14 M 0 4 8 12 16 20 4 4.5 5 5.5 6 6.5 7 7.5 8 INPUT POWER (dBm) FREQUENCY (GHz) R - S E
Noise Figure vs. Temperature Gain & Power vs. Supply Voltage
W 10 18 30 O 8 16 28 ) P1dB, (dB E ) 6 R 14 26 R & P U Psat IG (dB F A IN E 4 A 12 24 (dBm) IS G E O N +25C IN 2 +85C 10 22 -40C 0 8 20 5 5.5 6 6.5 7 4.75 5 5.25 S - L FREQUENCY (GHz) Vcc SUPPLY VOLTAGE (Vdc) R IE
Reverse Isolation vs. Temperature Power Down Isolation
LIF P 0 0 M -10 A -10 ) +25 C (dB -20 (dB +85 C N N -40 C IO IO -20 T T LA LA -30 O O IS IS -30 -40 -50 -40 4 4.5 5 5.5 6 6.5 7 7.5 8 4 5 6 7 8 FREQUENCY (GHz) FREQUENCY (GHz) For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
9 - 3
Phone: 781-329-4700 • Order online at www.analog.com Application Support: Phone: 1-800-ANALOG-D
