Datasheet HMC407MS8G, 407MS8GE (Analog Devices) - 6
DescriptionGaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 7 GHz
Pages / Page6 / 6 — HMC407MS8G / 407MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 5 - 7 GHz. …
File Format / SizePDF / 921 Kb
HMC407MS8G / 407MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 5 - 7 GHz. Evaluation PCB
HMC407MS8G / 407MS8GE GaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 7 GHz Evaluation PCB
v04.1019
9 T M R - S E W O R & P A E IN S - L R IE
List of Materials for Evaluation PCB 104987 [1]
The circuit board used in the final application should Item Description LIF use RF circuit design techniques. Signal lines should J1 - J2 PCB Mount SMA RF Connector P have 50 Ohm impedance while the package ground J3 2 mm DC Header M leads and exposed paddle should be connected C1 - C3 330 pF Capacitor, 0603 Pkg. A directly to the ground plane similar to that shown. A C4 2.2 µF Capacitor, Tantalum sufficient number of via holes should be used to con- U1 HMC407MS8G / HMC407MS8GE Amplifier nect the top and bottom ground planes. The evalua- PCB [2] 104628 Eval Board tion board should be mounted to an appropriate heat [1] Reference this number when ordering complete evaluation PCB sink. The evaluation circuit board shown is available [2] Circuit Board Material: Roger 4350 from Analog Devices, upon request. For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
9 - 6
Application Support: Phone: 1-800-ANALOG-D
