Datasheet HMC406MS8G, 406MS8GE (Analog Devices) - 3
DescriptionGaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 6 GHz
Pages / Page8 / 3 — HMC406MS8G / 406MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 5 - 6 GHz. …
File Format / SizePDF / 443 Kb
HMC406MS8G / 406MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 5 - 6 GHz. Power Compression @ 5.8 GHz. Output IP3 vs. Temperature
HMC406MS8G / 406MS8GE GaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 6 GHz Power Compression @ 5.8 GHz Output IP3 vs Temperature
v06.0611
GaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 6 GHz Power Compression @ 5.8 GHz Output IP3 vs. Temperature
42 44 T 36 39 (%) m s PAE 30 34 ) (dB), 24 +25 C (dBm 29 +85 C r - -40 C IP3 GAIN 18 e 24 w 12 (dBm), 19 o Pout (dBm) Pout 6 Gain (dB) p PAE (%) 14 4.5 5 5.5 6 6.5 0 0 2 4 6 8 10 12 14 16 18 FREQUENCY (GHz) INPUT POWER (dBm) r & A e
Noise Figure vs. Temperature Gain & Power vs. Supply Voltage
10 24 32 lin 9 23 31 8 22 30 ) P s - 7 21 29 1 (dB d E B r 6 20 28 R , U P IG 5 19 27 sa ie F t E 4 18 26 ( GAIN dB) d IS B O 3 17 25 m N +25 C ) lif +85 C 2 -40 C 16 24 P1dB p 1 15 Psat 23 Gain m 0 14 22 A 4.5 5 5.5 6 6.5 4.75 5 5.25 FREQUENCY (GHz) Vcc SUPPLY VOLTAGE (V)
Gain, Power & Quiescent Reverse Isolation vs. Temperature Supply Current vs. Vpd @ 5.8 GHz
0 33 350 30 315 -10 Reverse Isolation Power Down Isolation (dBm) 27 280 ) 24 245 -20 Psat (dB 21 210 Icq Ic N Bm), q IO -30 (d 18 175 (m T A) LA 15 140 O P1dB IS -40 12 105 Gain P1dB (dB), 9 Psat 70 -50 6 35 GAIN -60 3 0 4.5 5 5.5 6 6.5 2.5 3 3.5 4 4.5 5 FREQUENCY (GHz) Vpd (V) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
