Datasheet HMC406MS8G, 406MS8GE (Analog Devices) - 5
DescriptionGaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 6 GHz
Pages / Page8 / 5 — HMC406MS8G / 406MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 5 - 6 GHz. …
File Format / SizePDF / 443 Kb
HMC406MS8G / 406MS8GE. GaAs InGaP HBT MMIC. POWER AMPLIFIER, 5 - 6 GHz. Pin Descriptions
HMC406MS8G / 406MS8GE GaAs InGaP HBT MMIC POWER AMPLIFIER, 5 - 6 GHz Pin Descriptions
v06.0611
pin number function Description interface schematic T m s power Control pin. for maximum power, this pin should be 1 Vpd connected to 5V. A higher voltage is not recommended. for r - lower idle current, this voltage can be reduced. e w o Ground: Backside of package has exposed metal ground 2, 4, 7 GnD slug that must be connected to ground thru a short path. p Vias under the device are required. This pin is AC coupled 3 rfin and matched to 50 ohms. r & A rf output and bias for the output stage. The power supply e 5, 6 RFOUT for the output device needs to be supplied to these pins. lin power supply voltage for the first amplifier stage. An external bypass capacitor of 330 pf is required. This s - 8 Vcc capacitor should be placed as close to the devices as r possible. ie lif p m A Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd ho e ne r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o tniltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
