Datasheet HMC8411LP2FE (Analog Devices) - 4
DescriptionLow Noise Amplifier, 0.01 GHz to 10 GHz
Pages / Page23 / 4 — HMC8411LP2FE. Data Sheet. 6 GHz TO 10 GHz FREQUENCY RANGE. Table 3. …
File Format / SizePDF / 554 Kb
HMC8411LP2FE. Data Sheet. 6 GHz TO 10 GHz FREQUENCY RANGE. Table 3. Parameter. Symbol. Min. Typ. Max. Unit. Test Conditions/Comments
HMC8411LP2FE Data Sheet 6 GHz TO 10 GHz FREQUENCY RANGE Table 3 Parameter Symbol Min Typ Max Unit Test Conditions/Comments
VDD = 5 V, IDQ = 55 mA, and TA = 25°C, unless otherwise noted.
Table 3. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 6 10 GHz GAIN 11 14 dB Gain Variation over Temperature 0.018 dB/°C NOISE FIGURE 2 dB RETURN LOSS Input 15 dB Output 17 dB OUTPUT Output Power for 1 dB Compression P1dB 13 16 dBm Saturated Output Power PSAT 19.5 dBm Output Third-Order Intercept OIP3 33 dBm Measurement taken at POUT per tone = 6 dBm Output Second-Order Intercept OIP2 40 dBm Measurement taken at POUT per tone = 6 dBm POWER ADDED EFFICIENCY PAE 23 % Measured at PSAT SUPPLY CURRENT IDQ 55 mA SUPPLY VOLTAGE VDD 2 5 6 V Rev. B | Page 4 of 23 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications 0.01 GHz to 1 GHz Frequency Range 1 GHz to 6 GHz Frequency Range 6 GHz to 10 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Recommended Bias Sequencing During Power-Up During Power-Down Typical Application Circuit Evaluation Board Outline Dimensions Ordering Guide
