Datasheet HMC8411LP2FE (Analog Devices) - 10
Description | Low Noise Amplifier, 0.01 GHz to 10 GHz |
Pages / Page | 23 / 10 — HMC8411LP2FE. Data Sheet. +85°C +25°C –40°C. FIGU. OIS. 100. 120. 140. … |
Revision | B |
File Format / Size | PDF / 554 Kb |
HMC8411LP2FE. Data Sheet. +85°C +25°C –40°C. FIGU. OIS. 100. 120. 140. 160. 180. 200. FREQUENCY (MHz). FREQUENCY (GHz). 2V, IDD = 20mA
HMC8411LP2FE Data Sheet 10 6 +85°C +25°C –40°C 5 8 ) ) 4 dB dB ( ( E 6 E R R 3 FIGU FIGU E E 4 OIS OIS N N 2 2 1 +85°C +25°C –40°C 0 0 0 20 40 60 80 100 120 140 160 180 200
025
0 2 4 6 8 10 12
028
FREQUENCY (MHz)
15859-
FREQUENCY (GHz)
15859- Figure 25. Noise Figure vs. Frequency, 10 MHz to 200 MHz, for Figure 28. Noise Figure vs. Frequency, 200 MHz to 12 GHz, for Various Temperatures, VDD = 5 V, IDQ = 55 mA Various Temperatures, VDD = 5 V, IDQ = 55 mA
10 6 2V, IDD = 20mA 2V, IDD = 20mA 3V, IDD = 32mA 3V, IDD = 32mA 4V, IDD = 44mA 5 4V, IDD = 44mA 8 5V, IDD = 55mA 5V, IDD = 55mA 6V, IDD = 67mA 6V, IDD = 67mA ) ) 4 dB dB ( ( E 6 E R R 3 FIGU FIGU E E 4 OIS OIS N N 2 2 1 0 0 0 20 40 60 80 100 120 140 160 180 200
026
0 2 4 6 8 10 12
029
FREQUENCY (MHz)
15859-
FREQUENCY (GHz)
15859- Figure 26. Noise Figure vs. Frequency, 10 MHz to 200 MHz, for Figure 29. Noise Figure vs. Frequency, 200 MHz to 12 GHz, for Various Supply Voltages and IDD, RBIAS = 1.1 kΩ Various Supply Voltages and IDD, RBIAS = 1.1 kΩ
10 6 510Ω, I 510Ω, I DQ = 75mA DQ = 75mA 780Ω, I 780Ω, I DQ = 65mA DQ = 65mA 1.1kΩ, I 1.1kΩ, I DQ = 55mA 5 DQ = 55mA 8 1.8kΩ, I 1.8kΩ, I DQ = 45mA DQ = 45mA 3.0kΩ, I 3.0kΩ, I DQ = 35mA DQ = 35mA ) ) 4 dB dB ( ( E 6 E R R 3 FIGU FIGU E E 4 OIS OIS N N 2 2 1 0 0 0 20 40 60 80 100 120 140 160 180 200
027
0 2 4 6 8 10 12
030
FREQUENCY (MHz)
15859-
FREQUENCY (GHz)
15859- Figure 27. Noise Figure vs. Frequency, 10 MHz to 200 MHz, for Figure 30. Noise Figure vs. Frequency, 200 MHz to 12 GHz, for Various Bias Resistor Values and IDQ, VDD = 5 V Various Bias Resistor Values and IDQ, VDD = 5 V Rev. B | Page 10 of 23 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications 0.01 GHz to 1 GHz Frequency Range 1 GHz to 6 GHz Frequency Range 6 GHz to 10 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Recommended Bias Sequencing During Power-Up During Power-Down Typical Application Circuit Evaluation Board Outline Dimensions Ordering Guide
