Datasheet HMC8411LP2FE (Analog Devices) - 8
DescriptionLow Noise Amplifier, 0.01 GHz to 10 GHz
Pages / Page23 / 8 — HMC8411LP2FE. Data Sheet. +85°C. +25°C. –40°C. –10. URN L. –15. INP. –20. …
File Format / SizePDF / 554 Kb
HMC8411LP2FE. Data Sheet. +85°C. +25°C. –40°C. –10. URN L. –15. INP. –20. –25. 100. 125. 150. 175. 200. FREQUENCY (MHz). FREQUENCY (GHz). 2V, IDD = 20mA
HMC8411LP2FE Data Sheet +85°C +25°C –40°C –10 URN L –15 INP –20 –25 100 125 150 175 200 FREQUENCY (MHz) FREQUENCY (GHz) 2V, IDD = 20mA
HMC8411LP2FE Data Sheet 0 0 +85°C +85°C +25°C +25°C –40°C –40°C –5 –5 B) B) d d ( ( S S S S O –10 O –10 URN L URN L T T –15 –15 RE RE UT UT INP INP –20 –20 –25 –25 0 25 50 75 100 125 150 175 200
013
0 2 4 6 8 10 12
016
FREQUENCY (MHz)
15859-
FREQUENCY (GHz)
15859- Figure 13. Input Return Loss vs. Frequency, 10 MHz to 200 MHz, for Figure 16. Input Return Loss vs. Frequency, 200 MHz to 12 GHz, for Various Temperatures, VDD = 5 V, IDQ = 55 mA Various Temperatures, VDD = 5 V, IDQ = 55 mA
0 0 2V, IDD = 20mA 510Ω, IDQ = 75mA 3V, IDD = 32mA 780Ω, IDQ = 65mA 4V, IDD = 44mA 1.1kΩ, IDQ = 55mA 1.8kΩ, I –5 5V, IDD = 55mA –5 DQ = 45mA 6V, IDD = 67mA 3.0kΩ, IDQ = 35mA B) B) d d ( ( S S S S O –10 O –10 URN L URN L T T –15 –15 RE RE UT UT INP INP –20 –20 –25 –25 0 2 4 6 8 10 12
014
0 2 4 6 8 10 12
017
FREQUENCY (GHz)
15859-
FREQUENCY (GHz)
15859- Figure 14. Input Return Loss vs. Frequency for Various Supply Voltages and IDD, Figure 17. Input Return Loss vs. Frequency for Various Bias Resistor Values and IDQ, RBIAS = 1.1 kΩ VDD = 5 V
0 0 +85°C +85°C +25°C +25°C –40°C –40°C –5 B) –5 B) d d ( ( S S S S O O –10 URN L –10 URN L T T RE RE –15 UT UT P P UT –15 UT O O –20 –20 –25 0 25 50 75 100 125 150 175 200
015
0 2 4 6 8 10 12
018
FREQUENCY (MHz)
15859-
FREQUENCY (GHz)
15859- Figure 15. Output Return Loss vs. Frequency, 10 MHz to 200 MHz, for Figure 18. Output Return Loss vs. Frequency, 200 MHz to 12 GHz, for Various Temperatures, VDD = 5 V, IDQ = 55 mA Various Temperatures, VDD = 5 V, IDQ = 55 mA Rev. B | Page 8 of 23 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications 0.01 GHz to 1 GHz Frequency Range 1 GHz to 6 GHz Frequency Range 6 GHz to 10 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Recommended Bias Sequencing During Power-Up During Power-Down Typical Application Circuit Evaluation Board Outline Dimensions Ordering Guide
