Datasheet HMC8411LP2FE (Analog Devices) - 9
DescriptionLow Noise Amplifier, 0.01 GHz to 10 GHz
Pages / Page23 / 9 — Data Sheet. HMC8411LP2FE. 2V, I. 510Ω, I. DD = 20mA. DQ = 75mA. 3V, I. …
File Format / SizePDF / 554 Kb
Data Sheet. HMC8411LP2FE. 2V, I. 510Ω, I. DD = 20mA. DQ = 75mA. 3V, I. 780Ω, I. DD = 32mA. DQ = 65mA. 4V, I. 1.1kΩ, I. DD = 44mA. DQ = 55mA
Data Sheet HMC8411LP2FE 2V, I 510Ω, I DD = 20mA DQ = 75mA 3V, I 780Ω, I DD = 32mA DQ = 65mA 4V, I 1.1kΩ, I DD = 44mA DQ = 55mA
Data Sheet HMC8411LP2FE 0 0 2V, I 510Ω, I DD = 20mA DQ = 75mA 3V, I 780Ω, I DD = 32mA DQ = 65mA 4V, I 1.1kΩ, I DD = 44mA DQ = 55mA 1.8kΩ, I –5 5V, IDD = 55mA –5 DQ = 45mA B) 6V, I 3.0kΩ, I DD = 67mA B) DQ = 35mA d d ( ( S S S S O O –10 –10 URN L URN L T T RE –15 RE –15 UT UT P P UT UT O O –20 –20 –25 –25 0 2 4 6 8 10 12
019
0 2 4 6 8 10 12
022
FREQUENCY (GHz)
15859-
FREQUENCY (GHz)
15859- Figure 19. Output Return Loss vs. Frequency for Figure 22. Output Return Loss vs. Frequency for Various Supply Voltages and IDD, RBIAS = 1.1 kΩ Various Bias Resistor Values and IDQ, VDD = 5 V
0 0 +85°C +25°C –5 –40°C –5 ) ) B B –10 –10 (d (d N N IO IO T T A –15 A –15 L L SO SO –20 –20 SE I SE I EVER –25 EVER –25 R R –30 –30 +85°C +25°C –40°C –35 –35 0 25 50 75 100 125 150 175 200
020
0 2 4 6 8 10 12
023
FREQUENCY (MHz)
15859-
FREQUENCY (GHz)
15859- Figure 20. Reverse Isolation vs. Frequency, 10 MHz to 200 MHz, for Figure 23. Reverse Isolation vs. Frequency, 200 MHz to 12 GHz, for Various Temperatures, VDD = 5 V, IDQ = 55 mA Various Temperatures, VDD = 5 V, IDQ = 55 mA
0 0 –5 –5 ) ) B B –10 –10 (d (d N N IO IO T T A –15 A –15 L L SO SO –20 –20 SE I SE I EVER –25 EVER –25 R R 2V, IDD = 20mA 510Ω, IDQ = 75mA 3V, IDD = 32mA 780Ω, IDQ = 65mA –30 4V, IDD = 44mA –30 1.1kΩ, IDQ = 55mA 5V, IDD = 55mA 1.8kΩ, IDQ = 45mA 6V, IDD = 67mA 3.0kΩ, IDQ = 35mA –35 –35 0 2 4 6 8 10 12
021
0 2 4 6 8 10 12
024
FREQUENCY (GHz)
15859-
FREQUENCY (GHz)
15859- Figure 21. Reverse Isolation vs. Frequency for Figure 24. Reverse Isolation vs. Frequency for Various Supply Voltages and IDD, RBIAS = 1.1 kΩ Various Bias Resistor Values and IDQ, VDD = 5 V Rev. B | Page 9 of 23 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications 0.01 GHz to 1 GHz Frequency Range 1 GHz to 6 GHz Frequency Range 6 GHz to 10 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Recommended Bias Sequencing During Power-Up During Power-Down Typical Application Circuit Evaluation Board Outline Dimensions Ordering Guide
