Datasheet HMC8325 (Analog Devices) - 10
Description | 71 GHz to 86 GHz, E-Band Low Noise Amplifier |
Pages / Page | 16 / 10 — HMC8325. Data Sheet. ID3/ID4 = 3.0mA. ID3/ID4 = 15.0mA. ID3/ID4 = 20.0mA. … |
File Format / Size | PDF / 310 Kb |
HMC8325. Data Sheet. ID3/ID4 = 3.0mA. ID3/ID4 = 15.0mA. ID3/ID4 = 20.0mA. ID3/ID4 = 5.0mA. ID3/ID4 = 25.0mA. ID3/ID4 = 10.0mA
HMC8325 Data Sheet 20 20 ID3/ID4 = 3.0mA ID3/ID4 = 15.0mA ID3/ID4 = 3.0mA ID3/ID4 = 20.0mA 18 ID3/ID4 = 5.0mA ID3/ID4 = 20.0mA 19 ID3/ID4 = 5.0mA ID3/ID4 = 25.0mA ID3/ID4 = 10.0mA ID3/ID4 = 25.0mA ID3/ID4 = 10.0mA ID3/ID4 = 30.0mA ID3/ID4 = 30.0mA I 16 18 D3/ID4 = 15.0mA 14 17 Bm) d 12 16 B ( Bm) 1d d 10 ( 15 P AT UT S P 8 P 14 UT O 6 13 4 12 2 11 0 10 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
032
035
FREQUENCY (GHz)
14692-
FREQUENCY (GHz)
14692- Figure 32. Output P1dB vs. Frequency over Drain Current, VDx = 4 V, Figure 35. Saturated Output Power (PSAT) vs. Frequency over Drain Current, VG1 and VG2 Fixed at 20 mA, VG3 and VG4 Swept VDx = 4 V, VG1 and VG2 Fixed at 20 mA, VG3 and VG4 Swept
20 20 ID3/ID4 = 5.0mA ID3/ID4 = 25.0mA ID3/ID4 = 5.0mA ID3/ID4 = 25.0mA 18 ID3/ID4 = 10.0mA ID3/ID4 = 30.0mA 19 ID3/ID4 = 10.0mA ID3/ID4 = 30.0mA ID3/ID4 = 15.0mA ID3/ID4 = 35.0mA ID3/ID4 = 15.0mA ID3/ID4 = 35.0mA 16 ID3/ID4 = 20.0mA ID3/ID4 = 40.0mA 18 ID3/ID4 = 20.0mA ID3/ID4 = 40.0mA ID3/ID4 = 44.0mA ID3/ID4 = 44.0mA 14 17 Bm) d 12 16 B ( Bm) 1d d 10 ( 15 P AT UT S P 8 P 14 UT O 6 13 4 12 2 11 0 10 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
033
036
FREQUENCY (GHz)
14692-
FREQUENCY (GHz)
14692- Figure 33. Output P1dB vs. Frequency over Drain Current, Figure 36. Saturated Output Power (PSAT) vs. Frequency over Drain Current, VD1 and VD2 = 2 V, VD3 and VD4 = 4 V VD1 and VD2 = 2 V, VD3 and VD4 = 4 V
10 30 T 8 A = +85°C T 28 A = +85°C TA = +25°C TA = +25°C TA = –55°C 6 TA = –55°C 26 4 24 Bm) Bm) 2 d 22 d 3 ( 3 ( P P 0 I 20 I UT UT –2 P 18 INP UT O –4 16 –6 14 –8 12 –10 10 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86
034
037
FREQUENCY (GHz)
14692-
FREQUENCY (GHz)
14692- Figure 34. Input Third-Order Intercept (IP3) vs. Frequency over Temperature, Figure 37. Output Third-Order Intercept (IP3) vs. Frequency over VDx = 4 V, IDx = 50 mA Temperature, VDx = 4 V, IDx = 50 mA Rev. 0 | Page 10 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATION INFORMATION MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GAAS MMICS HANDLING PRECAUTIONS Storage Cleanliness Static Sensitivity Transients General Handling MOUNTING Eutectic Die Attach Epoxy Die Attach WIRE BONDING ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
