Datasheet HMC8402 (Analog Devices)
Description2 GHz to 30 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier
Pages / Page15 / 1 — 2 GHz to 30 GHz, GaAs, pHEMT, MMIC,. Low Noise Amplifier. Data Sheet. …
RevisionE
File Format / SizePDF / 380 Kb
2 GHz to 30 GHz, GaAs, pHEMT, MMIC,. Low Noise Amplifier. Data Sheet. HMC8402. FEATURES. GENERAL DESCRIPTION
Datasheet HMC8402 Analog Devices, Revision: E
2 GHz to 30 GHz, GaAs, pHEMT, MMIC, Low Noise Amplifier Data Sheet HMC8402 FEATURES GENERAL DESCRIPTION Output power for 1 dB compression (P1dB): 21.5 dBm typical
The HMC8402 is a gallium arsenide (GaAs), pseudomorphic
Saturated output power (PSAT): 22 dBm typical
high electron mobility transistor (pHEMT), monolithic microwave
Gain: 13.5 dB typical
integrated circuit (MMIC), low noise amplifier which operates
Noise figure: 2 dB
between 2 GHz and 30 GHz. The amplifier provides 13.5 dB of
Output third order intercept (IP3): 26 dBm typical
gain, 2 dB noise figure, 26 dBm output IP3, and 21.5 dBm of
Supply voltage: 7 V at 68 mA
output power at 1 dB gain compression while requiring 68 mA
50 Ω matched input/output
from a 7 V supply. The HMC8402 is self biased with only a single
Die size: 2.7 mm × 1.363 mm × 0.05 mm
positive supply needed to achieve a drain current IDQ of 68 mA.
The HMC8402 amplifier input/outputs are internal y matched to
Test instrumentation
50 Ω facilitating integration into multichip modules (MCMs). All
Microwave radios and very small aperture terminals (VSATs)
data is taken with the chip connected via two 0.025 mm (1 mil)
Military and space
wire bonds of minimal length 0.31 mm (12 mils).
Telecommunications infrastructure Fiber optics FUNCTIONAL BLOCK DIAGRAM 3 DD HMC8402 V 4 RFOUT VGG2 2 1 RFIN
001 13853- Figure 1.
Rev. E Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2016–2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS 2 GHz TO 18 GHz FREQUENCY RANGE 18 GHz TO 26 GHz FREQUENCY RANGE 26 GHz TO 30 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION BIASING PROCEDURES MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICs Handling Precautions Mounting Eutectic Die Attach Epoxy Die Attach Wire Bonding TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
