Datasheet HMC8400 (Analog Devices) - 3
Description2 GHz to 30 GHz, GaAs pHEMT MMIC Low Noise Amplifier
Pages / Page15 / 3 — Data Sheet. HMC8400. SPECIFICATIONS 2 GHz TO 6 GHz FREQUENCY RANGE. Table …
File Format / SizePDF / 313 Kb
Data Sheet. HMC8400. SPECIFICATIONS 2 GHz TO 6 GHz FREQUENCY RANGE. Table 1. Parameter. Symbol. Test Conditions/Comments. Min. Typ. Max
Data Sheet HMC8400 SPECIFICATIONS 2 GHz TO 6 GHz FREQUENCY RANGE Table 1 Parameter Symbol Test Conditions/Comments Min Typ Max
TA = 25°C, VDD = 5 V, IDD = 67 mA, VGG2 = open, unless otherwise stated. When using VGG2, it is recommended to limit VGG2 from −2 V to +2.6 V.
Table 1. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 2 6 GHz GAIN 12 14 dB Gain Variation Over Temperature 0.005 dB/°C RETURN LOSS Input 13 dB Output 15 dB OUTPUT Output Power for 1 dB Compression P1dB 13 16 dBm Saturated Output Power PSAT 19 dBm Output Third-Order Intercept IP3 Measurement taken at POUT/tone = 10 dBm 26.5 dBm NOISE FIGURE NF 3 5 dB SUPPLY CURRENT Total Supply Current IDD 67 mA Total Supply Current vs. VDD IDD = 64 mA 4 V IDD = 67 mA 5 V IDD = 70 mA 6 V SUPPLY VOLTAGE VDD 3 5 7 V
6 GHz TO 20 GHz FREQUENCY RANGE
Table 2. Parameter Symbol Test Conditions/Comments Min Typ Max Unit
FREQUENCY RANGE 6 20 GHz GAIN 11.5 13.5 dB Gain Variation Over Temperature 0.006 dB/°C RETURN LOSS Input 18 dB Output 15 dB OUTPUT Output Power for 1 dB Compression P1dB 12.5 14.5 dBm Saturated Output Power PSAT 17 dBm Output Third-Order Intercept IP3 Measurement taken at POUT/tone = 10 dBm 25 dBm NOISE FIGURE NF 2 3.5 dB SUPPLY CURRENT Total Supply Current IDD 67 mA Total Supply Current vs. VDD IDD = 64 mA 4 V IDD = 67 mA 5 V IDD = 70 mA 6 V SUPPLY VOLTAGE VDD 3 5 7 V Rev. B | Page 3 of 15 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM REVISION HISTORY SPECIFICATIONS 2 GHz TO 6 GHz FREQUENCY RANGE 6 GHz TO 20 GHz FREQUENCY RANGE 20 GHz TO 30 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION APPLICATIONS INFORMATION BIASING PROCEDURES MOUNTING AND BONDING TECHNIQUES FOR MILLIMETERWAVE GaAs MMICs Handling Precautions Mounting Eutectic Die Attach Epoxy Die Attach Wire Bonding TYPICAL APPLICATION CIRCUIT ASSEMBLY DIAGRAM OUTLINE DIMENSIONS ORDERING GUIDE
