Datasheet HMC1049SCPZ-EP (Analog Devices) - 10
Description | GaAs, pHEMT, MMIC, Low Noise Amplifier, 0.3 GHz to 20 GHz |
Pages / Page | 10 / 10 — HMC1049SCPZ-EP. Enhanced Product. PACKAGING AND ORDERING INFORMATION … |
File Format / Size | PDF / 267 Kb |
HMC1049SCPZ-EP. Enhanced Product. PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS. DETAIL A. (JEDEC 95). 5.10. 0.30. 5.00 SQ
HMC1049SCPZ-EP Enhanced Product PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS DETAIL A (JEDEC 95) 5.10 0.30 5.00 SQ 0.25 PIN 1 4.90 0.20 PIN 1 INDICATOR INDIC ATOR AREA OPTIONS (SEE DETAIL A) 25 32 24 1 0.50 3.80 BSC EXPOSED 3.70 SQ PAD 3.60 17 8 16 9 0.45 TOP VIEW BOTTOM VIEW 0.20 MIN 0.40 0.35 3.50 REF 0.80 0.75 SIDE VIEW 0.05 MAX FOR PROPER CONNECTION OF 0.70 THE EXPOSED PAD, REFER TO 0.02 NOM THE PIN CONFIGURATION AND COPLANARITY FUNCTION DESCRIPTIONS SEATING 0.08 SECTION OF THIS DATA SHEET. PLANE 0.203 REF A 2016- -005168 27- G K P COMPLIANT TO JEDEC STANDARDS MO-220-WHHD-4 10-
Figure 20. 32-Lead Lead Frame Chip Scale Package [LFCSP] 5 mm × 5 mm and 0.75 mm Package Height (CP-32-29) Dimensions shown in millimeters
ORDERING GUIDE Temperature Package Model1 Range Lead Finish Package Description Option
HMC1049SCPZ-EP-R7 −55°C to +105°C Nickel/palladium/gold (NiPdAu) 32-Lead Lead Frame Chip Scale Package [LFCSP] CP-32-29 1 Z = RoHS Compliant Part.
©2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. www.analog.com/HMC1049SCPZ-EP D17190-0-1/19(0)
Rev. 0 | Page 10 of 10 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 0.3 GHZ TO 1 GHZ FREQUENCY RANGE 1 GHZ TO 14 GHZ FREQUENCY RANGE 14 GHZ TO 20 GHZ FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER DERATING CURVES ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
