Datasheet HMC1049SCPZ-EP (Analog Devices) - 3
DescriptionGaAs, pHEMT, MMIC, Low Noise Amplifier, 0.3 GHz to 20 GHz
Pages / Page10 / 3 — Enhanced Product. HMC1049SCPZ-EP. SPECIFICATIONS 0.3 GHZ TO 1 GHZ …
File Format / SizePDF / 267 Kb
Enhanced Product. HMC1049SCPZ-EP. SPECIFICATIONS 0.3 GHZ TO 1 GHZ FREQUENCY RANGE. Table 1. Parameter1. Min. Typ. Max. Unit
Enhanced Product HMC1049SCPZ-EP SPECIFICATIONS 0.3 GHZ TO 1 GHZ FREQUENCY RANGE Table 1 Parameter1 Min Typ Max Unit
TA = 25°C, VDD = 7 V, IDD = 70 mA, 50 Ω system.
Table 1. Parameter1 Min Typ Max Unit
FREQUENCY RANGE 0.3 1 GHz GAIN 13.5 16 dB Gain Variation over Temperature 0.006 dB/°C NOISE FIGURE 2.5 3.5 dB RETURN LOSS Input 15 dB Output 8 dB OUTPUT Output Power for 1 dB Compression (P1dB) 16 dBm Saturated (PSAT) 18 dBm Output Third-Order Intercept (IP3)2 25 dBm TOTAL SUPPLY CURRENT 70 mA 1 Adjust VGG between −2 V and 0 V to achieve IDD = 70 mA typical. 2 Measurement taken at output power (POUT) per tone = 8 dBm.
1 GHZ TO 14 GHZ FREQUENCY RANGE
Table 2. Parameter1 Min Typ Max Unit
FREQUENCY RANGE 1 14 GHz GAIN 12 14 dB Gain Variation over Temperature 0.019 dB/°C NOISE FIGURE 2 3 dB RETURN LOSS Input 13 dB Output 15 dB OUTPUT Output Power for 1 dB Compression (P1dB) 15 dBm Saturated (PSAT) 17 dBm Output Third-Order Intercept (IP3)2 23 dBm TOTAL SUPPLY CURRENT 70 mA 1 Adjust VGG between −2 V and 0 V to achieve IDD = 70 mA typical. 2 Measurement taken at POUT per tone = 8 dBm. Rev. 0 | Page 3 of 10 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 0.3 GHZ TO 1 GHZ FREQUENCY RANGE 1 GHZ TO 14 GHZ FREQUENCY RANGE 14 GHZ TO 20 GHZ FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER DERATING CURVES ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
