Datasheet HMC1049SCPZ-EP (Analog Devices) - 4
DescriptionGaAs, pHEMT, MMIC, Low Noise Amplifier, 0.3 GHz to 20 GHz
Pages / Page10 / 4 — HMC1049SCPZ-EP. Enhanced Product. 14 GHZ TO 20 GHZ FREQUENCY RANGE. Table …
File Format / SizePDF / 267 Kb
HMC1049SCPZ-EP. Enhanced Product. 14 GHZ TO 20 GHZ FREQUENCY RANGE. Table 3. Parameter1. Min. Typ. Max. Unit
HMC1049SCPZ-EP Enhanced Product 14 GHZ TO 20 GHZ FREQUENCY RANGE Table 3 Parameter1 Min Typ Max Unit
TA = 25°C, VDD = 7 V, IDD = 70 mA, 50 Ω system.
Table 3. Parameter1 Min Typ Max Unit
FREQUENCY RANGE 14 20 GHz GAIN 10 12 dB Gain Variation over Temperature 0.017 dB/°C NOISE FIGURE 3.0 4.5 dB RETURN LOSS Input 14 dB Output 13 dB OUTPUT Output Power for 1 dB Compression (P1dB) 13 dBm Saturated (PSAT) 15 dBm Output Third-Order Intercept (IP3)2 18 dBm TOTAL SUPPLY CURRENT 70 mA 1 Adjust VGG between −2 V and 0 V to achieve IDD = 70 mA typical. 2 Measurement taken at POUT per tone = 8 dBm.
Table 4. Typical Supply Current vs. VDD Parameter Test Conditions/Comments Min Typ Max Unit
Supply Current, I 1 DD VDD = 5 V 70 mA VDD = 6 V 70 mA VDD = 7 V 70 mA 1 Adjust VGG to achieve IDD = 70 mA. Rev. 0 | Page 4 of 10 Document Outline FEATURES ENHANCED PRODUCT FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 0.3 GHZ TO 1 GHZ FREQUENCY RANGE 1 GHZ TO 14 GHZ FREQUENCY RANGE 14 GHZ TO 20 GHZ FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE POWER DERATING CURVES ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS PACKAGING AND ORDERING INFORMATION OUTLINE DIMENSIONS ORDERING GUIDE
