Datasheet HMC962LC4 (Analog Devices) - 3
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 7.5 - 26.5 GHz
Pages / Page6 / 3 — HMC962LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 7.5 - 26.5 GHz. P1dB vs. …
File Format / SizePDF / 374 Kb
HMC962LC4. GaAs pHEMT MMIC LOW NOISE. AMPLIFIER, 7.5 - 26.5 GHz. P1dB vs. Temperature. Psat vs. Temperature
HMC962LC4 GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 7.5 - 26.5 GHz P1dB vs Temperature Psat vs Temperature
HMC962LC4
v02.0614
GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 7.5 - 26.5 GHz P1dB vs. Temperature Psat vs. Temperature
17 19 T +25C m 15 +85C 17 -40C s 13 15 (dBm) (dBm) e - 11 13 P1dB P1dB is +25C o 9 11 +85C -40C 7 9 w N 7 9 11 13 15 17 19 21 23 25 27 7 9 11 13 15 17 19 21 23 25 27 FREQUENCY (GHz) FREQUENCY (GHz) lo s -
Reverse Isolation vs. Temperature Power Compression @ 10 GHz
r 0 24 ie Pout -10 20 Gain (%) PAE ) -20 PAE 16 lif p (dB N -30 (dB), 12 IO m T LA -40 GAIN 8 A O IS +25C -50 +85C 4 (dBm), -40C -60 Pout 0 -70 -4 6 8 10 12 14 16 18 20 22 24 26 28 -8 -6 -4 -2 0 2 4 6 8 FREQUENCY (GHz) INPUT POWER (dBm)
Power Compression @ 17 GHz Power Compression @ 24 GHz
24 24 Pout Pout 20 Gain 20 Gain (%) (%) PAE PAE PAE 16 PAE 16 (dB), (dB), 12 12 GAIN 8 GAIN 8 4 4 (dBm), (dBm), Pout 0 Pout 0 -4 -4 -8 -6 -4 -2 0 2 4 6 8 -8 -6 -4 -2 0 2 4 6 8 INPUT POWER (dBm) INPUT POWER (dBm) Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
