Datasheet HMC753 (Analog Devices)
Description1 GHz to 11 GHz, GaAs, HEMT, MMIC Low Noise Amplifier
Pages / Page13 / 1 — 1 GHz to 11 GHz, GaAs, HEMT,. MMIC Low Noise Amplifier. Data Sheet. …
RevisionE
File Format / SizePDF / 282 Kb
1 GHz to 11 GHz, GaAs, HEMT,. MMIC Low Noise Amplifier. Data Sheet. HMC753. FEATURES. FUNCTIONAL BLOCK DIAGRAM
Datasheet HMC753 Analog Devices, Revision: E
link to page 7 link to page 7
1 GHz to 11 GHz, GaAs, HEMT, MMIC Low Noise Amplifier Data Sheet HMC753 FEATURES FUNCTIONAL BLOCK DIAGRAM Noise figure: 1.5 dB at 4 GHz (see Figure 10) C C C C ND ND G NI NI NI NI G Gain 24 23 22 21 20 19 16.5 dB at 1 GHz to 6 GHz GND 1 HMC753 18 GND 14 dB at 6 GHz to 11 GHz GND 2 17 GND RFIN 3 16 RFOUT Output power for 1 dB compression (P1dB): 18 dBm GND 4 15 GND at 1 GHz to 6 GHz GND 5 14 GND Supply voltage (V GND 6 13 GND DD): 5 V at 55 mA Output third-order intercept (IP3): 30 dBm at 1 GHz to 6 GHz 7 8 9 1 10 1 12 2 1 C
001
50 Ω matched input/output (I/O) ND DD NI ND G GG GG V V V G
13494-
24-lead lead frame chip scale package (LFCSP): 16 mm2
Figure 1.
APPLICATIONS Point to point radios Point to multipoint radios Military and space Test instrumentation GENERAL DESCRIPTION
The HMC753 is a gallium arsenide (GaAs), monolithic The P1dB output power of up to 18 dBm at 1 GHz to 6 GHz microwave integrated circuit (MMIC), low noise, wideband enables the low noise amplifier (LNA) to function as a local amplifier housed in a leadless, 4 mm × 4 mm LFCSP. The amplifier oscil ator (LO) driver for balanced, I/Q, or image rejection operates between 1 GHz and 11 GHz, providing up to 16.5 dB mixers. The HMC753 also features I/Os that are dc blocked and of small signal gain at 1 GHz to 6 GHz, a 1.5 dB noise figure at internal y matched to 50 Ω, making the device ideal for high 4 GHz (see Figure 10), and an output IP3 of 30 dBm at 1 GHz to capacity microwave radios or very small aperture terminal (VSAT) 6 GHz, while requiring only 55 mA from a 5 V supply. applications.
Rev. E Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2015–2017 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Biasing Procedures Evaluation PCB Outline Dimensions Ordering Guide
