Datasheet HMC753 (Analog Devices) - 3
Description1 GHz to 11 GHz, GaAs, HEMT, MMIC Low Noise Amplifier
Pages / Page13 / 3 — Data Sheet. HMC753. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table 1. …
RevisionE
File Format / SizePDF / 282 Kb
Data Sheet. HMC753. SPECIFICATIONS ELECTRICAL SPECIFICATIONS. Table 1. Parameter. Min. Typ. Max. Unit. Test Conditions/Comments
Data Sheet HMC753 SPECIFICATIONS ELECTRICAL SPECIFICATIONS Table 1 Parameter Min Typ Max Unit Test Conditions/Comments
TA = 25°C, VDD = 5 V, IDD = 55 mA.
Table 1. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 1 6 GHz PERFORMANCE Gain 14 16.5 dB Gain Variation over Temperature 0.004 dB/°C Noise Figure 1.5 2 dB Input Return Loss 11 dB Output Return Loss 18 dB Output Power for 1 dB Compression (P1dB) 18 dBm Saturated Output Power (PSAT) 20 dBm Output Third Order Intercept (IP3) 30 dBm POWER SUPPLY Supply Current (IDD) 55 mA VDD = 5 V, set VGG2 = 1.5 V, VGG1 = −0.8 V typical
Table 2. Parameter Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 6 11 GHz PERFORMANCE Gain 10 14 dB Gain Variation over Temperature 0.008 dB/°C Noise Figure 2 2.7 dB Input Return Loss 8 dB Output Return Loss 12 dB Output Power for 1 dB Compression (P1dB) 15 dBm Saturated Output Power (PSAT) 17 dBm Output Third Order Intercept (IP3) 28 dBm POWER SUPPLY Supply Current (IDD) 55 mA VDD = 5 V, set VGG2 = 1.5 V, VGG1 = −0.8 V typical Rev. E | Page 3 of 13 Document Outline Features Applications Functional Block Diagram General Description Revision History Specifications Electrical Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Theory of Operation Applications Information Biasing Procedures Evaluation PCB Outline Dimensions Ordering Guide
