Datasheet HMC376LP3, 376LP3E (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 700 - 1000 MHz
Pages / Page6 / 3 — HMC376LP3 / 376LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 700 - 1000 …
File Format / SizePDF / 318 Kb
HMC376LP3 / 376LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 700 - 1000 MHz. P1dB vs. Temperature @ Idd = 73 mA
HMC376LP3 / 376LP3E GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 700 - 1000 MHz P1dB vs Temperature @ Idd = 73 mA
HMC376LP3 / 376LP3E
v01.0610
7
P1dB vs. Temperature @ Idd = 73 mA Psat vs. Temperature @ Idd = 73 mA
25 25 T 23 23 21 21 E - SM +25 C +25 C 19 19 IS +85 C P1dB (dBm) +85 C Psat (dBm) -40 C -40 C 17 17 15 15 W NO 0.7 0.75 0.8 0.85 0.9 0.95 1 0.7 0.75 0.8 0.85 0.9 0.95 1 O FREQUENCY (GHz) FREQUENCY (GHz) - L
Gain, Noise Figure &
S
Output IP3 vs. Temperature @ Idd = 73 mA Power vs. Supply Current @ 900 MHz
R 40 24 1 IE IF 22 38 L NOISE FIGURE (dB) 20 0.8 P Noise figure 36 M 18 GAIN P1dB A IP3 (dBm) 34 16 0.6 +25 C GAIN (dB) & P1dB (dBm) 32 +85 C 14 -40 C 30 12 0.4 0.7 0.75 0.8 0.85 0.9 0.95 1 60 70 80 90 100 110 120 FREQUENCY (GHz) SUPPLY CURRENT (mA)
Typical Supply Current vs. Vdd Absolute Maximum Ratings with Rbias = 10 Ohms
Drain Bias Voltage (Vdd) +8.0 Vdc Vdd (Vdc) Idd (mA) RF Input Power (RFIN)(Vs = +5.0 Vdc) +15 dBm +4.5 73.0 Channel Temperature 150 °C +5.0 73.4 Continuous Pdiss (T = 85 °C) +5.5 73.6 0.769 W (derate 11.83 mW/°C above 85 °C) Thermal Resistance 84.5 °C/W (channel to ground paddle)
Recommended Bias Resistor Values
Storage Temperature -65 to +150 °C
for Various Idd
Operating Temperature -40 to +85 °C Idd (mA) Rbias (Ohms) 60 12 70 10 ELECTROSTATIC SENSITIVE DEVICE 80 9.1 OBSERVE HANDLING PRECAUTIONS 100 6.8 120 5.1 Information furnish F e o d r pri by An ce, de alog Devic leis vie s rby eli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No : 978 Phon -e25 : 7 0 81 - - 3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
7 - 3
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
