Datasheet HMC374, 374E (Analog Devices)
DescriptionSMT PHEMT LOW NOISE AMPLIFIER, 0.3 - 3.0 GHz
Pages / Page6 / 1 — HMC374 / 374E. SMT PHEMT LOW NOISE. AMPLIFIER, 0.3 - 3.0 GHz. Typical …
File Format / SizePDF / 326 Kb
HMC374 / 374E. SMT PHEMT LOW NOISE. AMPLIFIER, 0.3 - 3.0 GHz. Typical Applications. Features. Functional Diagram
Datasheet HMC374, 374E Analog Devices
HMC374 / 374E
v00.0405
8
Typical Applications Features
The HMC374 / HMC374E is ideal for: Single Supply: Vdd = +2.75 to +5.5V T • Cellular/PCS/3G Low Noise Figure: 1.5 dB • WCS, MMDS & ISM High Output IP3: +37 dBm - SM • Fixed Wireless & WLAN No External Matching Required S R • Private Land Mobile Radio IE IF L
P M The HMC374 & HMC374E are general purpose broad band Low Noise Amplifi ers (LNA) for use in the 0.3 - 3 GHz frequency range. The LNA provides 15 dB of E A gain and a 1.5 dB noise fi gure from a single positive IS supply of +2.75 to +5.5V. The low noise fi gure coupled with a high P1dB (22 dBm) and high OIP3 (37 dBm) make this part ideal for cellular applications. The compact LNA design utilizes on-chip matching for W NO repeatable gain and noise fi gure performance. To O L minimize board area the design is offered in a low cost SOT26 package that occupies only 0.118” x 0.118”.
Electrical Specifi cations, T = +25° C, Vdd= +5V A
Parameter Min. Typ. Max. Min. Typ. Max. Min. Typ. Max. Units Frequency Range 0.3 - 1.0 1.0 - 2.0 2.0 - 3.0 GHz Gain 12 15 10 13 6 9 dB Gain Variation Over Temperature 0.01 0.02 0.01 0.02 0.01 0.02 dB/°C Noise Figure 1.5 1.9 1.6 2.0 1.8 2.2 dB Input Return Loss 5 8 13 dB Output Return Loss 7 9 9 dB Output 1 dB Compression (P1dB) 22 22 22 dBm Saturated Output Power (Psat) 23 23 23 dBm Output Third Order Intercept (IP3) 37 37 37 dBm Supply Current (Idd) (Vdd = +5V) 90 90 90 mA Information furnish F e o d r pri by An ce, de alog Devic leis vie s rbyeli, a eve nd to pla d to be accur ce o ate an r d der relia s ble , pl . Ho ease co wever, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other ntact Hittite Microwave Corporation: One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 20 Alpha Road, Chelmsford, MA 01824 Phone rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. : 978 Phon -e25 : 7 0 81 -3 3 3 29 4 - 3 F 470 ax 0 • O : 978 rder o - nl 25 in 0 e a - t 33 ww 73
8 - 60
w.analog.com Order On- Trademarks and registered trademarks are the property of their respective owners. line at www.hi A tptipte.co licatio m n Support: Phone: 1-800-ANALOG-D
