Datasheet HMC519LC4 (Analog Devices) - 4
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 18 - 31 GHz
Pages / Page6 / 4 — HMC519LC4. Gaas PHEMT MMIC LOW NOIsE. aMPLIFIER, 18 - 31 GHz. absolute …
HMC519LC4. Gaas PHEMT MMIC LOW NOIsE. aMPLIFIER, 18 - 31 GHz. absolute Maximum Ratings. Typical supply Current vs. Vdd
HMC519LC4 Gaas PHEMT MMIC LOW NOIsE aMPLIFIER, 18 - 31 GHz absolute Maximum Ratings Typical supply Current vs Vdd
HMC519LC4
v04.1017
Gaas PHEMT MMIC LOW NOIsE aMPLIFIER, 18 - 31 GHz absolute Maximum Ratings Typical supply Current vs. Vdd
Drain Bias Voltage (Vdd1, Vdd2, Vdd3) +3.5 Vdc Vdd (V) Idd (mA) RF Input Power (RFIN)(Vdd = +3.0 Vdc) +20 dBm 2.5 72 T Channel Temperature 175 °C 3.0 75 M 3.5 78 Continuous Pdiss (T= 85 °C) 1.2 W (derate 13 mW/°C above 85 °C) Note: Amplifier will operate over full voltage ranges shown Thermal Resistance above. 76.9 °C/W (channel to package bottom) S - S R Storage Temperature -65 to 150 °C ELECTROSTATIC SENSITIVE DEVICE IE Operating Temperature -40 to 85 °C OBSERVE HANDLING PRECAUTIONS ESD Sensitivity (HBM) Class 1B LIF P
24-Terminal Ceramic Leadless Chip Carrier [LCC] (E-24-1)
M
Outline Drawing Dimensions shown in millimeters.
E A
4.05 0.36
IS
3.90 SQ 0.30 PIN 1 3.75 0.08
O
0.24 INDICATOR BSC PIN 1 19 24 18 1 0.50 2.60
W N
BSC EXPOSED PAD 2.50 SQ 2.40
LO
13 6 12 7 TOP VIEW 0.32 BOTTOM VIEW BSC 2.50 REF 1.00 3.10 BSC 0.90 SIDE VIEW 0.80 FOR PROPER CONNECTION OF THE EXPOSED PAD, REFER TO THE PIN CONFIGURATION AND SEATING FUNCTION DESCRIPTIONS PLANE SECTION OF THIS DATA SHEET. PKG-004840 02-27-2017-B
24-Terminal Ceramic Leadless Chip Carrier [LCC] (E-24-1) Dimensions shown in mil imeters.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [2] HMC519LC4 Alumina, White Gold over Nickel MSL3 [1] H519 XXXX [1] Max peak reflow temperature of 260 °C [2] 4-Digit lot number XXXX For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
4
Application Support: Phone: 1-800-ANALOG-D
