Datasheet HMC462LP5, 462LP5E (Analog Devices) - 4
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 2 - 20 GHz
Pages / Page6 / 4 — HMC462LP5 / 462LP5E. GAAS PHEMT MMIC. LOW NOISE AMPLIFIER, 2 - 20 GHz. …
File Format / SizePDF / 378 Kb
HMC462LP5 / 462LP5E. GAAS PHEMT MMIC. LOW NOISE AMPLIFIER, 2 - 20 GHz. Outline Drawing. Package Information
HMC462LP5 / 462LP5E GAAS PHEMT MMIC LOW NOISE AMPLIFIER, 2 - 20 GHz Outline Drawing Package Information
HMC462LP5 / 462LP5E
v05.0213
T M E - S IS O W N O S - L R IE NOTES: 1. LEADFRAME MATERIAL: COPPER ALLOY LIF 2. DIMENSIONS ARE IN INCHES [MILLIMETERS] P 3. LEAD SPACING TOLERANCE IS NON-CUMULATIVE. 4. PAD BURR LENGTH SHALL BE 0.15mm MAXIMUM. M PAD BURR HEIGHT SHALL BE 0.05mm MAXIMUM. A 5. PACKAGE WARP SHALL NOT EXCEED 0.05mm. 6. ALL GROUND LEADS AND GROUND PADDLE MUST BE SOLDERED TO PCB RF GROUND. 7. REFER TO HITTITE APPLICATION NOTE FOR SUGGESTED LAND PATTERN.
Package Information
Part Number Package Body Material Lead Finish MSL Rating Package Marking [3] HMC462LP5 Low Stress Injection Molded Plastic Sn/Pb Solder MSL1 [1] H462 XXXX HMC462LP5E RoHS-compliant Low Stress Injection Molded Plastic 100% matte Sn MSL1 [2] H462 XXXX [1] Max peak reflow temperature of 235 °C [2] Max peak reflow temperature of 260 °C [3] 4-Digit lot number XXXX Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com
4
Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
