Datasheet HMC462LP5, 462LP5E (Analog Devices) - 5
DescriptionGaAs pHEMT MMIC LOW NOISE AMPLIFIER, 2 - 20 GHz
Pages / Page6 / 5 — HMC462LP5 / 462LP5E. GaAs pHEMT MMIC. LOW NOISE AMPLIFIER, 2 - 20 GHz. …
File Format / SizePDF / 378 Kb
HMC462LP5 / 462LP5E. GaAs pHEMT MMIC. LOW NOISE AMPLIFIER, 2 - 20 GHz. Pin Descriptions
HMC462LP5 / 462LP5E GaAs pHEMT MMIC LOW NOISE AMPLIFIER, 2 - 20 GHz Pin Descriptions
HMC462LP5 / 462LP5E
v05.0213
Pin Number Function Description Interface Schematic T 1 - 4, 6 - 20, No connection. These pins may be connected to RF ground. M N/C 22 - 29, 31, 32 Performance will not be affected. This pad is AC coupled 5 RFIN and matched to 50 Ohms. E - S This pad is AC coupled 21 RFOUT and matched to 50 Ohms. IS O W N Power supply voltage for the amplifier. 30 Vdd O External bypass capacitors are required. S - L R IE Ground Paddle GND Ground paddle must be connected to RF/DC ground. LIF P M A Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 p o lica rti a o p n S p u s p @ po h rt itt : P ite ho . n c e om : 1-800-ANALOG-D
