Datasheet HMC375LP3, 375LP3E (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 1.7 - 2.2 GHz
Pages / Page6 / 3 — HMC375LP3 / 375LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 1.7 - 2.2 GHz. …
File Format / SizePDF / 333 Kb
HMC375LP3 / 375LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 1.7 - 2.2 GHz. Input Return Loss vs. Temperature
HMC375LP3 / 375LP3E GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 1.7 - 2.2 GHz Input Return Loss vs Temperature
HMC375LP3 / 375LP3E
v03.0610
7
Input Return Loss vs. Temperature Output Return Loss vs. Temperature
0 0 T +25 C +25 C -5 -40 C -5 +85 C +85 C -40 C -10 -10 E - SM -15 -15 IS RETURN LOSS (dB) RETURN LOSS (dB) -20 -20 -25 -25 W NO 1.7 1.8 1.9 2 2.1 2.2 1.7 1.8 1.9 2 2.1 2.2 O FREQUENCY (GHz) FREQUENCY (GHz) - L S
Output IP3 vs. Temperature P1dB & PSAT vs. Temperature
R 40 24 IE +25 C +25 C IF 38 PSAT +85 C 22 +85 C L -40 C -40 C P 36 20 M A IP3 (dBm) 34 18 COMPRESSION (dBm) 32 16 P1dB 30 14 1.7 1.8 1.9 2 2.1 2.2 1.7 1.8 1.9 2 2.1 2.2 FREQUENCY (GHz) FREQUENCY (GHz)
Output IP3 vs. Vdd P1dB vs. Vdd
40 24 +4.5 V 22 38 +5.0 V +5.5 V 20 36 18 IP3 (dBm) 34 16 +4.5 V OUTPUT P1dB (dBm) +5.0 V 32 +5.5 V 14 30 12 1.7 1.8 1.9 2 2.1 2.2 1.7 1.8 1.9 2 2.1 2.2 FREQUENCY (GHz) FREQUENCY (GHz) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
7 - 76
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
