Datasheet HMC356LP3, 356LP3E (Analog Devices) - 3
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 350 - 550 MHz
Pages / Page6 / 3 — HMC356LP3 / 356LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 350 - 550 MHz. …
File Format / SizePDF / 406 Kb
HMC356LP3 / 356LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 350 - 550 MHz. Input Return Loss vs. Temperature
HMC356LP3 / 356LP3E GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 350 - 550 MHz Input Return Loss vs Temperature
HMC356LP3 / 356LP3E
v03.0610
7
Input Return Loss vs. Temperature Output Return Loss vs. Temperature
0 0 T -5 -5 +25 C +25 C -10 +85 C -10 +85 C -40 C -40 C E - SM -15 -15 IS RETURN LOSS (dB) RETURN LOSS (dB) -20 -20 -25 -25 W NO 0.3 0.35 0.4 0.45 0.5 0.55 0.6 0.3 0.35 0.4 0.45 0.5 0.55 0.6 O FREQUENCY (GHz) FREQUENCY (GHz) - L S
Output IP3 vs. Temperature P1dB & Psat vs. Temperature
R 42 26 IE PSAT 41 25 IF 40 24 L 39 23 P 38 22 M 37 21 A 36 20 35 OUTPUT IP3 (dBm) 19 +25 C COMPRESSION (dBm) +85 C 34 P1dB +25 C 18 -40 C +85 C 33 -40 C 17 32 16 0.3 0.35 0.4 0.45 0.5 0.55 0.6 0.3 0.35 0.4 0.45 0.5 0.55 0.6 FREQUENCY (GHz) FREQUENCY (GHz)
Output IP3 vs. Vdd P1dB vs. Vdd
42 26 41 25 40 24 39 23 38 22 37 21 36 20 35 +4.5 V OUTPUT IP3 (dBm) 19 +5.0 V COMPRESSION (dBm) 34 +5.5 V 18 +4.5 V +5.0 V 33 17 +5.5 V 32 16 0.3 0.35 0.4 0.45 0.5 0.55 0.6 0.3 0.35 0.4 0.45 0.5 0.55 0.6 FREQUENCY (GHz) FREQUENCY (GHz) Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
7 - 48
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
