Datasheet HMC356LP3, 356LP3E (Analog Devices) - 5
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 350 - 550 MHz
Pages / Page6 / 5 — HMC356LP3 / 356LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 350 - 550 MHz. …
File Format / SizePDF / 406 Kb
HMC356LP3 / 356LP3E. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 350 - 550 MHz. Pin Descriptions
HMC356LP3 / 356LP3E GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 350 - 550 MHz Pin Descriptions
HMC356LP3 / 356LP3E
v03.0610
7
Pin Descriptions
T Pin Number Function Description Interface Schematic 1, 5, 8, 9, 10, No connection necessary. N/C 12, 13, 14 These pins may be connected to RF/DC ground. These pins and package ground paddle 2, 4, 6,16 GND E - SM must be connected to RF/DC ground. IS This pin is matched to 50 Ohms with a 51 nH 3 RFIN inductor to ground. See Application Circuit. W NO AC Ground - An external capacitor of 0.01μF to O 7 ACG ground is required for low frequency bypassing. See Application Circuit for further details. - L S R 11 RFOUT This pin is AC coupled and matched to 50 Ohms. IE IF L Power supply voltage. Choke inductor and bypass P 15 Vdd capacitor are required. See application circuit. M A
Application & Evaluation PCB Circuit
Note 1: Choose value of capacitor C1 for low frequency bypassing. A 0.01 μF ±10% capacitor is recommended. Note 2: L1, L2 and C1 should be located as close to pins as possible. Info F rmoatr pr ion f iurcne, de ished b ly iv A e n r al y o a g D n evd to p ices is bla eli c eve o ed t rde o be ras: H ccuratite tiatne M d reli iacr ble ow . Ho av wev e C er, n o o rpo Fora r t p iro ic n e ,, 2 d 0 eli A ve lrpha R y, and toad, C o place hoel rd m er s s fo : Ard, MA 01 nalog Devic 8 e 2 s 4 , Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rde hone r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .ehit r o t nilte in .c e ao t m
7 - 50
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r app tion Su s p @ po h rt itt : P ite ho .c ne o : 1m -800-ANALOG-D
