Datasheet HMC342LC4 (Analog Devices) - 5
DescriptionGaAs PHEMT MMIC LOW NOISE AMPLIFIER, 13 - 25 GHz
Pages / Page6 / 5 — HMC342LC4. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 13 - 25 GHz. Pin …
File Format / SizePDF / 343 Kb
HMC342LC4. GaAs PHEMT MMIC LOW NOISE. AMPLIFIER, 13 - 25 GHz. Pin Descriptions. Application Circuit
HMC342LC4 GaAs PHEMT MMIC LOW NOISE AMPLIFIER, 13 - 25 GHz Pin Descriptions Application Circuit
HMC342LC4
v04.0514
Pin Number Function Description Interface Schematic T 1, 5 - 14, No connection required. These pins may be connected to M N/C 18 - 20, 22 - 24 RF/DC ground without affecting performance. Package base has an exposed metal ground that must 2, 4, 15, 17 GND also be connected to RF/DC ground. S - S R This pin is AC coupled 3 RFIN and matched to 50 Ohms. IE This pin is AC coupled 16 RFOUT and matched to 50 Ohms. LIF P Power Supply Voltage for the amplifier. External bypass 21 Vdd M capacitors of 100 pF, 1000pF, and 2.2 µF are required. E A IS O W N LO
Application Circuit
Component Value C1 100 pF C2 1,000 pF C3 2.2 µF Inf F or o m r p atio r n ifc ur e n , d ishe e d lbiv y e A r n y a alog n D d t evic o p es is la beclie o eved rd to ebre sa: H ccur iattti e tae M nd re ilicarbloew . H a o ve C wever, o n rp o For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other oration, 2 Elizabeth Drive, Chelmsford, MA 01824 One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 978-250-3343 Fax: 978-250-3373 O rights of third parties that may result from its use. Specifications subject to change without notice. No P rd hone e r O : 7 n 81- -3li 2n 9 e a -47 t w 0 w 0 • O w rd .h e it r o t niltie n .c e ao t m
5
license is granted by implication or otherwise under any patent or patent rights of Analog Devices. www.analog.com Application Support: Pho Trademarks and registered trademarks are the property of their respective owners. ne: 978-250-33 A 4 p 3 o plica r a tio p n S p u s p @ po h rt itt : P ite ho . n c e o : 1m -800-ANALOG-D
