Datasheet ADPA9002 (Analog Devices)
DescriptionGaAs, pHEMT, MMIC, Single Positive Supply, DC to 10 GHz Power Amplifier
Pages / Page19 / 1 — GaAs, pHEMT, MMIC, Single Positive Supply,. DC to 10 GHz Power Amplifier. …
File Format / SizePDF / 319 Kb
GaAs, pHEMT, MMIC, Single Positive Supply,. DC to 10 GHz Power Amplifier. Data Sheet. ADPA9002. FEATURES
Datasheet ADPA9002 Analog Devices
GaAs, pHEMT, MMIC, Single Positive Supply, DC to 10 GHz Power Amplifier Data Sheet ADPA9002 FEATURES FUNCTIONAL BLOCK DIAGRAM OP1dB: 29 dBm typical ADPA9002 1 2 Gain: up to 15 dB typical C C C C ND ND OIP3: up to 43 dBm typical G NI ACG ACG NI NI NI G 32 31 30 29 28 27 26 25 Self biased at VDD = 12 V at 385 mA typical with an optional bias control on VGG1 for IDQ adjustment GND 1 24 GND 50 Ω matched input/output NIC 2 23 NIC NIC 3 22 GND 32-lead, 5 mm × 5 mm LFCSP GND 4 21 RFOUT/VDD RFIN 5 20 GND APPLICATIONS GND 6 19 NIC NIC 7 18 NIC Military and space GND 8 17 GND Test instrumentation 9 PACKAGE 10 11 12 13 14 15 16 BASE C C C C 3
001
ND NI NI NI NI ND G GG1V G ACG GND
21196- Figure 1.
GENERAL DESCRIPTION
The ADPA9002 is a gallium arsenide (GaAs), pseudomorphic test equipment applications. The ADPA9002 also features inputs high electron mobility transistor (pHEMT), monolithic and outputs that are internal y matched to 50 Ω, housed in a microwave integrated circuit (MMIC), power amplifier that RoHS compliant, 5 mm × 5 mm LFCSP premolded cavity operates between dc and 10 GHz. The amplifier provides 15 dB package, making it compatible with high volume surface-mount of gain, 42 dBm of OIP3, and 31.5 dBm of saturated output technology (SMT) assembly equipment. power (PSAT) while requiring 385 mA from a 12 V supply. The Note that throughout this data sheet, multifunction pins, such ADPA9002 is self biased in normal operation and has an as RFOUT/VDD, are referred to either by the entire pin name or optional bias control for supply quiescent current (IDQ) by a single function of the pin, for example, VDD, when only that adjustment. The amplifier is ideal for military and space and function is relevant.
Rev. 0 Document Feedback Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other rights of third parties that may result from its use. Specifications subject to change without notice. No One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 ©2019 Analog Devices, Inc. All rights reserved. Trademarks and registered trademarks are the property of their respective owners. Technical Support www.analog.com
Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC TO 2 GHz 2 GHz TO 5 GHz 5 GHz TO 10 GHz ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS CONSTANT IDD OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATION CIRCUIT OUTLINE DIMENSIONS ORDERING GUIDE
