Datasheet ADPA9002 (Analog Devices) - 3
DescriptionGaAs, pHEMT, MMIC, Single Positive Supply, DC to 10 GHz Power Amplifier
Pages / Page19 / 3 — Data Sheet. ADPA9002. SPECIFICATIONS DC TO 2 GHz. Table 1. Parameter. …
File Format / SizePDF / 319 Kb
Data Sheet. ADPA9002. SPECIFICATIONS DC TO 2 GHz. Table 1. Parameter. Symbol. Min Typ. Max. Unit. Test Conditions/Comments
Data Sheet ADPA9002 SPECIFICATIONS DC TO 2 GHz Table 1 Parameter Symbol Min Typ Max Unit Test Conditions/Comments
TA = 25°C, VDD = 12 V, IDQ = 385 mA, VGG1= GND for nominal self biased operation, and frequency range = dc to 2 GHz, with a 50 Ω matched input and output, unless otherwise noted.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE DC 2 GHz GAIN 12.5 14.5 dB Gain Variation Over Temperature ±0.01 dB/°C NOISE FIGURE 5 dB RETURN LOSS Input 18 dB Output 14 dB OUTPUT Output Power for 1 dB Compression OP1dB 27 29 dBm Saturated Output Power PSAT 31 dBm Output Third-Order Intercept OIP3 43 dBm Measurement taken at output power (POUT) per tone = 14 dBm SUPPLY Quiescent Current IDQ 385 mA For external bias control, adjust VGG1 between −2 V and +0.5 V to achieve the desired IDQ Drain Voltage VDD 10 12 15 V
2 GHz TO 5 GHz
TA = 25°C, VDD = 12 V, IDQ = 385 mA, VGG1 = GND for nominal self biased operation, and frequency range = 2 GHz to 5 GHz, unless otherwise noted. 50 Ω matched input/output.
Table 2. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 2 5 GHz GAIN 13 15 dB Gain Variation Over Temperature ±0.008 dB/°C NOISE FIGURE 3 dB RETURN LOSS Input 14 dB Output 15 dB OUTPUT Output Power for 1 dB Compression OP1dB 27 29 dBm Saturated Output Power PSAT 31.5 dBm Output Third-Order Intercept OIP3 42 dBm Measurement taken at POUT per tone = 14 dBm SUPPLY Quiescent Current IDQ 385 mA For external bias control, adjust VGG1 between −2 V and +0.5 V to achieve the desired IDQ Drain Voltage VDD 10 12 15 V Rev. 0 | Page 3 of 19 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS DC TO 2 GHz 2 GHz TO 5 GHz 5 GHz TO 10 GHz ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS CONSTANT IDD OPERATION THEORY OF OPERATION APPLICATIONS INFORMATION TYPICAL APPLICATION CIRCUIT OUTLINE DIMENSIONS ORDERING GUIDE
