Datasheet ADPA7002 (Analog Devices) - 3
DescriptionGaAs, pHEMT, MMIC, 1/2 W, 18 GHz to 44 GHz, Power Amplifier
Pages / Page21 / 3 — Data Sheet. ADPA7002. SPECIFICATIONS 18 GHz TO 20 GHz FREQUENCY RANGE. …
File Format / SizePDF / 505 Kb
Data Sheet. ADPA7002. SPECIFICATIONS 18 GHz TO 20 GHz FREQUENCY RANGE. Table 1. Parameter. Symbol. Min. Typ. Max Unit
Data Sheet ADPA7002 SPECIFICATIONS 18 GHz TO 20 GHz FREQUENCY RANGE Table 1 Parameter Symbol Min Typ Max Unit
TA = 25°C, drain voltage (VDD) = 5 V, and quiescent drain current (IDQ) = 700 mA for nominal operation, unless otherwise noted.
Table 1. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 18 20 GHz GAIN 15 dB Flatness ±0.5 dB Variation over Temperature 0.026 dB/°C NOISE FIGURE 11 dB RETURN LOSS Input 8 dB Output 13 dB OUTPUT Power for 1 dB Compression P1dB 25.5 dBm Saturated Output Power PSAT 27.5 dBm Third-Order Intercept IP3 36.5 dBm Measurement taken at output power (POUT) per tone = 12 dBm POWER ADDED EFFICIENCY PAE 12.5 % Measured at PSAT SUPPLY Quiescent Drain Current IDQ 700 mA Adjust VGG1 between −1.5 V to 0 V to achieve the desired IDQ Drain Voltage VDD 4 5 V
20 GHz TO 24 GHz FREQUENCY RANGE
TA = 25°C, VDD = 5 V, and IDQ = 700 mA for nominal operation, unless otherwise noted.
Table 2. Parameter Symbol Min Typ Max Unit Test Conditions/Comments
FREQUENCY RANGE 20 24 GHz GAIN 15 17 dB Flatness ±0.5 dB Variation over Temperature 0.026 dB/°C NOISE FIGURE 8 dB RETURN LOSS Input 12 dB Output 12 dB OUTPUT Power for 1 dB Compression P1dB 24 27 dBm Saturated Output Power PSAT 28.5 dBm Third-Order Intercept IP3 37 dBm Measurement taken at POUT per tone = 12 dBm POWER ADDED EFFICIENCY PAE 14 % Measured at PSAT SUPPLY Quiescent Drain Current IDQ 700 mA Adjust VGG1 between −1.5 V to 0 V to achieve the desired IDQ Drain Voltage VDD 4 5 V Rev. 0 | Page 3 of 21 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications 18 GHz to 20 GHz Frequency Range 20 GHz to 24 GHz Frequency Range 24 GHz to 34 GHz Frequency Range 34 GHz to 44 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Constant IDD Operation Theory of Operation Applications Information Biasing Procedures Biasing the ADPA7002 with the HMC980LP4E Application Circuit Setup Limiting VGATE to Meet the ADPA7002 VGG1 AMR Requirement HMC980LP4E Bias Sequence Constant Drain Current Biasing vs. Constant Gate Voltage Biasing Testing the HMC980LP4E Outline Dimensions Ordering Guide
