Datasheet ADPA7002 (Analog Devices) - 5
DescriptionGaAs, pHEMT, MMIC, 1/2 W, 18 GHz to 44 GHz, Power Amplifier
Pages / Page21 / 5 — Data Sheet. ADPA7002. ABSOLUTE MAXIMUM RATINGS Table 5. THERMAL …
File Format / SizePDF / 505 Kb
Data Sheet. ADPA7002. ABSOLUTE MAXIMUM RATINGS Table 5. THERMAL RESISTANCE. Parameter. Rating. Table 6. Thermal Resistance
Data Sheet ADPA7002 ABSOLUTE MAXIMUM RATINGS Table 5 THERMAL RESISTANCE Parameter Rating Table 6 Thermal Resistance
Data Sheet ADPA7002 ABSOLUTE MAXIMUM RATINGS Table 5. THERMAL RESISTANCE Parameter Rating
Thermal performance is directly linked to printed circuit board VDDX 6.0 V (PCB) design and operating environment. Careful attention to VGG1 −1.6 V to 0 V PCB thermal design is required. RF Input Power (RFIN) 25 dBm Continuous Power Dissipation (P
DISS), TA = 6.21 W 85°C (Derate 69 mW/°C above 85°C)
Package Type θJC Unit
Temperature EH-16-11 14.5 °C/W Storage Range −65°C to +150°C 1 Thermal resistance (θJC) is determined by simulation under the following Operating Range −40°C to +85°C conditions: the heat transfer is due solely to thermal conduction from the Nominal Junction (T channel, through the ground pin, to the PCB, and the ground pin is held A = 85°C, VDD = 5 V, 135.75°C I constant at the operating temperature of 85°C. DQ = 700 mA) Junction to Maintain 1,000,000 Hour 175°C Mean Time to Failure (MTTF)
ESD CAUTION
Electrostatic Discharge (ESD) Sensitivity Human Body Model (HBM) Class 1A (passed 500 V) Stresses at or above those listed under Absolute Maximum Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. 0 | Page 5 of 21 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications 18 GHz to 20 GHz Frequency Range 20 GHz to 24 GHz Frequency Range 24 GHz to 34 GHz Frequency Range 34 GHz to 44 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Constant IDD Operation Theory of Operation Applications Information Biasing Procedures Biasing the ADPA7002 with the HMC980LP4E Application Circuit Setup Limiting VGATE to Meet the ADPA7002 VGG1 AMR Requirement HMC980LP4E Bias Sequence Constant Drain Current Biasing vs. Constant Gate Voltage Biasing Testing the HMC980LP4E Outline Dimensions Ordering Guide
