Datasheet ADPA7002 (Analog Devices) - 10
DescriptionGaAs, pHEMT, MMIC, 1/2 W, 18 GHz to 44 GHz, Power Amplifier
Pages / Page21 / 10 — ADPA7002. Data Sheet. 4V 5V. Bm). B (. FREQUENCY (GHz). 600mA. 700mA. …
File Format / SizePDF / 505 Kb
ADPA7002. Data Sheet. 4V 5V. Bm). B (. FREQUENCY (GHz). 600mA. 700mA. 800mA. Bm) d. d (. UT O. +85°C +25°C. –40°C. T P. AT S. 600mA 700mA
ADPA7002 Data Sheet 4V 5V Bm) B ( FREQUENCY (GHz) 600mA 700mA 800mA Bm) d d ( UT O +85°C +25°C –40°C T P AT S 600mA 700mA
ADPA7002 Data Sheet 36 36 34 34 4V 5V 32 32 30 30 28 28 Bm) Bm) d 26 d 26 B ( B ( 1d 24 24 1d P 22 P 22 UT UT P 20 P 20 UT UT O 18 O 18 16 16 14 14 12 12 10 10
022
18 20 22 24 26 28 30 32 34 36 38 40 42 44
025
18 20 22 24 26 28 30 32 34 36 38 40 42 44 FREQUENCY (GHz) FREQUENCY (GHz)
20071- 20071- Figure 22. Output P1dB vs. Frequency for Various Temperatures Figure 25. Output P1dB vs. Frequency for Various Drain Voltages
36 36 34 600mA 34 700mA 32 800mA 32 30 30 28 28 Bm) d 26 26 B ( 24 Bm) 24 1d d ( P 22 AT 22 UT S P 20 P 20 UT O 18 18 16 16 14 14 +85°C +25°C 12 12 –40°C 10 10
023
026
20071- 20071- Figure 23. Output P1dB vs. Frequency for Various Currents Figure 26. PSAT vs. Frequency for Various Temperatures
36 36 4V 34 34 5V 32 32 30 30 28 28 Bm) d 26 26 ( AT 24 Bm) 24 S d ( T P 22 22 U AT S 20 P TP 20 OU 18 18 16 16 14 14 600mA 700mA 12 12 800mA 10 10
024 027
18 20 22 24 26 28 30 32 34 36 38 40 42 44 18 20 22 24 26 28 30 32 34 36 38 40 42 44
20071-
20071- Figure 24. Output PSAT vs. Frequency for Various Drain Voltages Figure 27. PSAT vs. Frequency for Various Quiescent Drain Currents Rev. 0 | Page 10 of 21 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications 18 GHz to 20 GHz Frequency Range 20 GHz to 24 GHz Frequency Range 24 GHz to 34 GHz Frequency Range 34 GHz to 44 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Constant IDD Operation Theory of Operation Applications Information Biasing Procedures Biasing the ADPA7002 with the HMC980LP4E Application Circuit Setup Limiting VGATE to Meet the ADPA7002 VGG1 AMR Requirement HMC980LP4E Bias Sequence Constant Drain Current Biasing vs. Constant Gate Voltage Biasing Testing the HMC980LP4E Outline Dimensions Ordering Guide
