Datasheet ADPA7002 (Analog Devices) - 9
DescriptionGaAs, pHEMT, MMIC, 1/2 W, 18 GHz to 44 GHz, Power Amplifier
Pages / Page21 / 9 — Data Sheet. ADPA7002. 600mA. +85°C. 700mA. +25°C. 800mA. –40°C. –10. URN …
File Format / SizePDF / 505 Kb
Data Sheet. ADPA7002. 600mA. +85°C. 700mA. +25°C. 800mA. –40°C. –10. URN L. –15. INP. UT O. –20. –25. FREQUENCY (GHz). 700mA 800mA. ) B –20. A –30. FIGU. –40
Data Sheet ADPA7002 600mA +85°C 700mA +25°C 800mA –40°C –10 URN L –15 INP UT O –20 –25 FREQUENCY (GHz) 700mA 800mA ) B –20 A –30 FIGU –40
Data Sheet ADPA7002 0 0 600mA +85°C 700mA +25°C 800mA –40°C –5 –5 B) B) d d ( ( S S S S O O –10 –10 URN L URN L T T –15 RE –15 RE UT UT P INP UT O –20 –20 –25 –25
016 019
18 20 22 24 26 28 30 32 34 36 38 40 42 44 18 20 22 24 26 28 30 32 34 36 38 40 42 44 FREQUENCY (GHz) FREQUENCY (GHz)
20071- 20071- Figure 16. Input Return Loss vs. Frequency for Various Quiescent Drain Currents Figure 19. Output Return Loss vs. Frequency for Various Temperatures
0 0 4V 600mA 5V 700mA 800mA –5 –5 B) B) d d ( ( S S S S O –10 O –10 URN L URN L T T RE –15 RE –15 UT UT P P UT UT O O –20 –20 –25 –25
017
020
20071- 20071- Figure 17. Output Return Loss vs. Frequency for Various Drain Voltages Figure 20. Output Return Loss vs. Frequency for Various Quiescent Drain Currents
0 20 +85°C +85°C 18 +25°C –10 +25°C –40°C –40°C 16 ) B –20 14 (d ) N dB IO ( 12 T E A –30 R L 10 SO FIGU –40 E SE I 8 OIS N 6 EVER –50 R 4 –60 2 –70 0
018
021
20071- 20071- Figure 18. Reverse Isolation vs. Frequency for Various Temperatures Figure 21. Noise Figure vs. Frequency for Various Temperatures Rev. 0 | Page 9 of 21 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications 18 GHz to 20 GHz Frequency Range 20 GHz to 24 GHz Frequency Range 24 GHz to 34 GHz Frequency Range 34 GHz to 44 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Constant IDD Operation Theory of Operation Applications Information Biasing Procedures Biasing the ADPA7002 with the HMC980LP4E Application Circuit Setup Limiting VGATE to Meet the ADPA7002 VGG1 AMR Requirement HMC980LP4E Bias Sequence Constant Drain Current Biasing vs. Constant Gate Voltage Biasing Testing the HMC980LP4E Outline Dimensions Ordering Guide
