Datasheet ADPA7002 (Analog Devices) - 6
DescriptionGaAs, pHEMT, MMIC, 1/2 W, 18 GHz to 44 GHz, Power Amplifier
Pages / Page21 / 6 — ADPA7002. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. DD3. …
File Format / SizePDF / 505 Kb
ADPA7002. Data Sheet. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. DD3. 11 VDD4. DD1. TOP VIEW. VDD2. (Not to Scale). GG1. VGG1. FIN
ADPA7002 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS DD3 11 VDD4 DD1 TOP VIEW VDD2 (Not to Scale) GG1 VGG1 FIN
ADPA7002 Data Sheet PIN CONFIGURATION AND FUNCTION DESCRIPTIONS UT F T O RE ND ND DE V G RF G V 16 15 14 13 12 V 1 DD3 11 VDD4 ADPA7002 V 2 DD1 10 TOP VIEW VDD2 V 3 (Not to Scale) GG1 9 VGG1 4 5 6 7 8 C C NI ND FIN ND NI G R G NOTES 1. NIC = NO INTERNAL CONNECTION. THESE PINS HAVE NO INTERNAL CONNECTIONS. CONNECT TO GROUND.
002
2. EXPOSED PAD. THE EXPOSED PAD MUST BE CONNECTED TO RF AND DC GROUND.
20071- Figure 2. Pin Configuration
Table 7. Pin Function Descriptions Pin No. Mnemonic Description
1, 2, 10, 11 VDD3, VDD1, VDD2, VDD4 Drain Biases. External bypass capacitors are required. 3, 9 VGG1 Gate Bias Controls. External bypass capacitors are required. 4, 8 NIC No Internal Connection. These pins have no internal connections. Connect to ground. 5, 7, 13, 15 GND Ground. These pins must be connected to RF and dc ground. 6 RFIN RF Signal Input. This pin is ac-coupled and matched to 50 Ω. 12 VDET Detector Diode to Measure RF Output Power. Output power detection via this pin requires the application of a dc bias voltage through an external series resistor. Used in combination with the VREF pin, the difference voltage (VREF − VDET) is a temperature compensated dc voltage that is proportional to the RF output power. 14 RFOUT RF Signal Output. This pin is ac-coupled and matched to 50 Ω. 16 VREF Reference Diode for Temperature Compensation of VDET RF Output Power Measurements. EPAD Exposed Pad. The exposed pad must be connected to RF and dc ground. Rev. 0 | Page 6 of 21 Document Outline Features Applications Functional Block Diagram General Description Table of Contents Revision History Specifications 18 GHz to 20 GHz Frequency Range 20 GHz to 24 GHz Frequency Range 24 GHz to 34 GHz Frequency Range 34 GHz to 44 GHz Frequency Range Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Constant IDD Operation Theory of Operation Applications Information Biasing Procedures Biasing the ADPA7002 with the HMC980LP4E Application Circuit Setup Limiting VGATE to Meet the ADPA7002 VGG1 AMR Requirement HMC980LP4E Bias Sequence Constant Drain Current Biasing vs. Constant Gate Voltage Biasing Testing the HMC980LP4E Outline Dimensions Ordering Guide
