Datasheet ADPA7002CHIP (Analog Devices) - 2
DescriptionGaAs, pHEMT, MMIC,1/2 W, 20 GHz to 44 GHz, Power Amplifier
Pages / Page23 / 2 — ADPA7002CHIP. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 4/2020—Rev. …
RevisionC
File Format / SizePDF / 532 Kb
ADPA7002CHIP. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY 4/2020—Rev. B to Rev. C. 7/2019—Rev. 0 to Rev. A
ADPA7002CHIP Data Sheet TABLE OF CONTENTS REVISION HISTORY 4/2020—Rev B to Rev C 7/2019—Rev 0 to Rev A
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 3 link to page 3 link to page 4 link to page 4 link to page 4 link to page 5 link to page 6 link to page 7 link to page 14 link to page 15 link to page 16 link to page 17 link to page 18 link to page 18 link to page 22 link to page 22 link to page 23 link to page 23
Features .. 1 Typical Performance Characteristics ..7 Applications ... 1 Constant Drain Current (IDD) Operation .. 14 Functional Block Diagram .. 1 Theory of Operation .. 15 General Description ... 1 ADPA7002CHIP Assembly and Circuit Diagrams ... 16 Revision History ... 2 Alternate Assembly Diagram .. 17 Specifications ... 3 Biasing Procedures ... 18 20 GHz to 34 GHz Frequency Range ... 3 Biasing the ADPA7002CHIP with the HMC980LP4E .. 18 34 GHz to 44 GHz Frequency Range ... 3 Mounting and Bonding Techniques for Millimeter Wave Absolute Maximum Ratings .. 4 GaAs MMICs .. 22 Thermal Resistance .. 4 Outline Dimensions ... 23 ESD Caution .. 4 Ordering Guide .. 23 Pin Configuration and Function Descriptions ... 5 Interface Schematics... 6
Changes to Figure 2 and Table 5 .. 5 Changes to Figure 1 and General Description Section ... 1 Changes to Typical Performance Characteristics Section ... 7 Changes to Figure 2 and Table 5 ... 5 Changes to Figure 54 and Figure 55 .. 16 Changes to Figure 7 and Figure 9 ... 6 Changes to Biasing Procedures Section, Biasing the Changes to Constant Drain Current (IDD) Operation Section . ... .. 14 ADPA7002CHIP with the HMC980LP4E, and Application Changes to Figure 54 and Figure 55 ... 16 Circuit Setup Section ... 18 Changes to Bias Procedures Section and Biasing the Changes to Constant Drain Current Biasing vs. Constant Gate ADPA7002CHIP with the HMC980LP4E Section .. 18 Voltage Biasing Section .. 20 Changes to Figure 59 and Figure 60 ... 19 Changes to HMC980LP4E Bias Sequence Section and Constant
Drain Current Biasing vs. Constant Gate Voltage Biasing Added Thermal Resistance Section and Table 4; Renumbered Section .. 20 Sequentially .. 4 Deleted Testing the HMC980LP4E Section .. 21 Changes to Figure 10 ... 7 Changes to Figure 63 to Figure 66 .. 21 Updated Outline Dimensions ... 23
2/2019—Revision 0: Initial Version 2/2020—Rev. A to Rev. B
Changes to Figure 1 .. 1 Changes to Supply Parameter, Table 1 and Table 2 .. 3 Change to Table 3 ... 4 Rev. C | Page 2 of 23 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 20 GHz TO 34 GHz FREQUENCY RANGE 34 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS CONSTANT DRAIN CURRENT (IDD) OPERATION THEORY OF OPERATION ADPA7002CHIP ASSEMBLY AND CIRCUIT DIAGRAMS ALTERNATE ASSEMBLY DIAGRAM BIASING PROCEDURES BIASING THE ADPA7002CHIP WITH THE HMC980LP4E Application Circuit Setup Limiting VGATE to Meet ADPA7002CHIP VGGx AMR Requirement HMC980LP4E Bias Sequence Constant Drain Current Bias vs. Constant Gate Voltage Bias MOUNTING AND BONDING TECHNIQUES FOR MILLIMETER WAVE GAAS MMICS Handling Precautions Mounting Wire Bonding OUTLINE DIMENSIONS ORDERING GUIDE
