Datasheet ADPA7002CHIP (Analog Devices) - 10
DescriptionGaAs, pHEMT, MMIC,1/2 W, 20 GHz to 44 GHz, Power Amplifier
Pages / Page23 / 10 — ADPA7002CHIP. Data Sheet. ) 14. 4.0V. E (%. +85°C. 5.0V. +25°C. PA 10. …
RevisionC
File Format / SizePDF / 532 Kb
ADPA7002CHIP. Data Sheet. ) 14. 4.0V. E (%. +85°C. 5.0V. +25°C. PA 10. –55°C. FREQUENCY (GHz). 1020. POUT GAIN. 960. PAE. IDD. 900. , P B). 840. N (. mA). 700mA
ADPA7002CHIP Data Sheet ) 14 4.0V E (% +85°C 5.0V +25°C PA 10 –55°C FREQUENCY (GHz) 1020 POUT GAIN 960 PAE IDD 900 , P B) 840 N ( mA) 700mA
ADPA7002CHIP Data Sheet 24 24 22 22 20 20 18 18 16 16 ) 14 ) 14 4.0V E (% 12 12 E (% +85°C 5.0V PA 10 +25°C PA 10 –55°C 8 8 6 6 4 4 2 2 0 0 20 22 24 26 28 30 32 34 36 38 40 42 44
028
0 5 10 15 20 25 30 35 40 45 50
031
FREQUENCY (GHz) FREQUENCY (GHz)
17236- 17236- Figure 28. Power Added Efficiency (PAE) vs. Frequency over Temperature, Figure 31. PAE vs. Frequency for Various Drain Voltages, PAE Measured at PSAT PAE Measured at PSAT
24 35 1020 22 POUT GAIN 30 960 20 PAE %) IDD 18 ( 25 900 AE 16 , P B) ) 14 d 20 840 N ( mA) E (% 12 700mA AI ( 600mA PA , G 15 780 I DD 10 800mA Bm) 8 d ( 10 720 6 UT OP 4 5 660 2 0 600 0 –4 –2 0 2 4 6 8 10 12 14 16 18
032
029
INPUT POWER (dBm)
17236-
FREQUENCY (GHz)
17236- Figure 29. PAE vs. Frequency for Various Quiescent Drain Currents, Figure 32. POUT, Gain, PAE, and IDD vs. Input Power, Frequency = 22 GHz PAE Measured at PSAT
35 1230 35 1230 POUT POUT 30 GAIN 1140 30 GAIN 1140 PAE PAE %) I %) ( DD I ( DD 25 1050 AE 25 1050 AE , P , P B) B) d 20 960 d 20 960 N ( mA) N ( mA) AI ( AI ( , G 15 870 I DD , G 15 870 I DD Bm) Bm) d d ( 10 780 ( 10 780 UT UT O O P P 5 690 5 690 0 600 0 600 –5 –3 –1 1 3 5 7 9 11 13 15 17
030
033
INPUT POWER (dBm)
17236-
INPUT POWER (dBm)
17236- Figure 30. POUT, Gain, PAE, and IDD vs. Input Power, Frequency = 26 GHz Figure 33. POUT, Gain, PAE, and IDD vs. Input Power, Frequency = 30 GHz Rev. C | Page 10 of 23 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 20 GHz TO 34 GHz FREQUENCY RANGE 34 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS CONSTANT DRAIN CURRENT (IDD) OPERATION THEORY OF OPERATION ADPA7002CHIP ASSEMBLY AND CIRCUIT DIAGRAMS ALTERNATE ASSEMBLY DIAGRAM BIASING PROCEDURES BIASING THE ADPA7002CHIP WITH THE HMC980LP4E Application Circuit Setup Limiting VGATE to Meet ADPA7002CHIP VGGx AMR Requirement HMC980LP4E Bias Sequence Constant Drain Current Bias vs. Constant Gate Voltage Bias MOUNTING AND BONDING TECHNIQUES FOR MILLIMETER WAVE GAAS MMICS Handling Precautions Mounting Wire Bonding OUTLINE DIMENSIONS ORDERING GUIDE
