Datasheet ADPA7002CHIP (Analog Devices) - 8
DescriptionGaAs, pHEMT, MMIC,1/2 W, 20 GHz to 44 GHz, Power Amplifier
Pages / Page23 / 8 — ADPA7002CHIP. Data Sheet. 700mA. +85°C. 600mA. +25°C. 800mA. –55°C. –10. …
RevisionC
File Format / SizePDF / 532 Kb
ADPA7002CHIP. Data Sheet. 700mA. +85°C. 600mA. +25°C. 800mA. –55°C. –10. URN L. –15. INP. UT O. –20. –25. FREQUENCY (GHz). 5.0V. 4.0V. RE –15. –30. –40. FIGU E
ADPA7002CHIP Data Sheet 700mA +85°C 600mA +25°C 800mA –55°C –10 URN L –15 INP UT O –20 –25 FREQUENCY (GHz) 5.0V 4.0V RE –15 –30 –40 FIGU E
ADPA7002CHIP Data Sheet 0 0 700mA +85°C –5 600mA –5 +25°C 800mA B) –55°C B) d d ( ( S S S S O O –10 –10 URN L URN L T T –15 RE –15 RE UT UT P INP UT O –20 –20 –25 –25 20 22 24 26 28 30 32 34 36 38 40 42 44
016
019
FREQUENCY (GHz)
17236-
FREQUENCY (GHz)
17236- Figure 16. Input Return Loss vs. Frequency for Various Quiescent Drain Figure 19. Output Return Loss vs. Frequency for Various Temperatures Currents
0 20 5.0V 600mA 4.0V 700mA 18 800mA –5 B) B) d d ( ( 16 S S S S O O –10 14 URN L URN L T T 12 RE –15 RE UT UT P P 10 UT UT O O –20 8 –25 6 20 22 24 26 28 30 32 34 36 38 40 42 44
017
020
FREQUENCY (GHz)
17236-
FREQUENCY (GHz)
17236- Figure 17. Output Return Loss vs. Frequency for Various Drain Voltages Figure 20. Output Return Loss vs. Frequency for Various Quiescent Drain Currents
0 20 18 –10 +85°C +85°C +25°C +25°C 16 ) –55°C –55°C B –20 (d ) 14 N dB IO ( T E 12 –30 A R L 10 SO –40 FIGU E SE I 8 OIS N –50 6 EVER R 4 –60 2 –70 0 20 22 24 26 28 30 32 34 36 38 40 42 44
018
021
FREQUENCY (GHz)
17236-
FREQUENCY (GHz)
17236- Figure 18. Reverse Isolation vs. Frequency for Various Temperatures Figure 21. Noise Figure vs. Frequency for Various Temperatures Rev. C | Page 8 of 23 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 20 GHz TO 34 GHz FREQUENCY RANGE 34 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS CONSTANT DRAIN CURRENT (IDD) OPERATION THEORY OF OPERATION ADPA7002CHIP ASSEMBLY AND CIRCUIT DIAGRAMS ALTERNATE ASSEMBLY DIAGRAM BIASING PROCEDURES BIASING THE ADPA7002CHIP WITH THE HMC980LP4E Application Circuit Setup Limiting VGATE to Meet ADPA7002CHIP VGGx AMR Requirement HMC980LP4E Bias Sequence Constant Drain Current Bias vs. Constant Gate Voltage Bias MOUNTING AND BONDING TECHNIQUES FOR MILLIMETER WAVE GAAS MMICS Handling Precautions Mounting Wire Bonding OUTLINE DIMENSIONS ORDERING GUIDE
