Datasheet ADPA7002CHIP (Analog Devices) - 9
DescriptionGaAs, pHEMT, MMIC,1/2 W, 20 GHz to 44 GHz, Power Amplifier
Pages / Page23 / 9 — Data Sheet. ADPA7002CHIP. Bm). B (. +85°C. 4.0V. +25°C. 5.0V. –55°C. …
RevisionC
File Format / SizePDF / 532 Kb
Data Sheet. ADPA7002CHIP. Bm). B (. +85°C. 4.0V. +25°C. 5.0V. –55°C. FREQUENCY (GHz). Bm) d. 700mA. 600mA. 800mA. 600mA 800mA
Data Sheet ADPA7002CHIP Bm) B ( +85°C 4.0V +25°C 5.0V –55°C FREQUENCY (GHz) Bm) d 700mA 600mA 800mA 600mA 800mA
Data Sheet ADPA7002CHIP 36 36 34 34 32 32 30 30 28 28 Bm) Bm) d 26 d 26 B ( B ( 24 24 1d 1d P 22 P 22 UT UT P 20 P 20 UT +85°C UT 4.0V O 18 +25°C O 18 5.0V –55°C 16 16 14 14 12 12 10 10 20 22 24 26 28 30 32 34 36 38 40 42 44
022
025
FREQUENCY (GHz)
17236-
FREQUENCY (GHz)
17236- Figure 22. Output P1dB vs. Frequency for Various Temperatures Figure 25. Output P1dB vs. Frequency for Various Drain Voltages
36 36 34 34 32 32 30 30 28 28 Bm) d 26 26 B ( 24 Bm) 24 1d d P ( 22 22 AT UT S P 20 P 20 UT 700mA +85°C O 18 600mA 18 +25°C 800mA –55°C 16 16 14 14 12 12 10 10 20 22 24 26 28 30 32 34 36 38 40 42 44
023
026
FREQUENCY (GHz) FREQUENCY (GHz)
17236- 17236- Figure 23. Output P1dB vs. Frequency for Various Quiescent Drain Currents Figure 26. PSAT vs. Frequency for Various Temperatures
36 36 34 34 32 32 30 30 28 28 26 26 Bm) 24 Bm) 24 d d ( ( 22 22 AT AT S S P 20 P 20 4.0V 700mA 18 5.0V 18 600mA 800mA 16 16 14 14 12 12 10 10 20 22 24 26 28 30 32 34 36 38 40 42 44
027
024
17236- 17236- Figure 24. P Figure 27. P SAT vs. Frequency for Various Drain Voltages SAT vs. Frequency for Various Quiescent Drain Currents Rev. C | Page 9 of 23 Document Outline FEATURES APPLICATIONS FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS 20 GHz TO 34 GHz FREQUENCY RANGE 34 GHz TO 44 GHz FREQUENCY RANGE ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS INTERFACE SCHEMATICS TYPICAL PERFORMANCE CHARACTERISTICS CONSTANT DRAIN CURRENT (IDD) OPERATION THEORY OF OPERATION ADPA7002CHIP ASSEMBLY AND CIRCUIT DIAGRAMS ALTERNATE ASSEMBLY DIAGRAM BIASING PROCEDURES BIASING THE ADPA7002CHIP WITH THE HMC980LP4E Application Circuit Setup Limiting VGATE to Meet ADPA7002CHIP VGGx AMR Requirement HMC980LP4E Bias Sequence Constant Drain Current Bias vs. Constant Gate Voltage Bias MOUNTING AND BONDING TECHNIQUES FOR MILLIMETER WAVE GAAS MMICS Handling Precautions Mounting Wire Bonding OUTLINE DIMENSIONS ORDERING GUIDE
