Datasheet HMC863ALC4 (Analog Devices) - 9
DescriptionGaAs pHEMT MMIC 1/2 WATT POWER AMPLIFIER, 24 - 29.5 GHz
Pages / Page11 / 9 — HMC863ALC4. GaAs pHEMT MMIC 1/2 WATT. POWER AMPLIFIER, 24 - 29.5 GHz. Pin …
File Format / SizePDF / 930 Kb
HMC863ALC4. GaAs pHEMT MMIC 1/2 WATT. POWER AMPLIFIER, 24 - 29.5 GHz. Pin Descriptions. 9 - 9
HMC863ALC4 GaAs pHEMT MMIC 1/2 WATT POWER AMPLIFIER, 24 - 29.5 GHz Pin Descriptions 9 - 9
HMC863ALC4
v02.0118
Pin Number Function Description Interface Schematic 1, 2, 4 - 7, 12 - 15, These pins & exposed ground paddle must be connected to 17 - 19, 24 GND RF/DC ground. Package Bottom 9 3 RFIN The pin is AC coupled and matched to 50 Ohms. These pins are not connected internally; however, all data 8 - 11, 22, 21 N/C shown herein was measured with these pins connected to RF/DC ground externally. T M 16 RFOUT The pin is AC coupled and matched to 50 Ohms. R - S E Drain bias for amplifier. External 100 pF, 0.1 uF and 4.7 uF 20 Vd bypass capacitors are required. W O Gate control for amplifier. Adjust VGG to achieve recom- 23 Vgg1 mended bias current. External 100 pF, 0.1 uF and 4.7 uF R & P bypass capacitors are required. A E IN S - L R IE LIF P M A For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
9 - 9
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Gain & Return Loss Absolute Maximum Ratings Outline Drawing Package Information Pin Descriptions Evaluation PCB List of Materials Application Circuit
