Datasheet HMC952ALP5GE (Analog Devices) - 9
DescriptionGaAs pHEMT MMIC 2 Watt POWER AMPLIFIER WITH POWER DETECTOR 8 - 14 GHz
Pages / Page10 / 9 — HMC952ALP5GE. GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER. WITH POWER DETECTOR …
File Format / SizePDF / 844 Kb
HMC952ALP5GE. GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER. WITH POWER DETECTOR 8 - 14 GHz. Evaluation PCB
HMC952ALP5GE GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER WITH POWER DETECTOR 8 - 14 GHz Evaluation PCB
HMC952ALP5GE
v03.0418
T m s r - e w o p r & A e lin s - r ie lif p m A
List of Materials for Evaluation PCB EV1HMC952ALP5G [1]
item Description The circuit board used in the application should use J1, J2, J5, J6 K Connector sri rf circuit design techniques. signal lines should J3, J4 DC pin have 50 ohm impedance while the package ground C2, C3, C9, C12, leads and exposed paddle should be connected C14, C16, C17, 100 pf Capacitor, 0402 pkg. directly to the ground plane similar to that shown. C19 A sufficient number of via holes should be used to C1, C4, C10, C11, C13, C15, C18, 10 nf Capacitor, 0402 pkg. connect the top and bottom ground planes. The C20 evaluation circuit board shown is available from C21, C22, C25 4.7uf Capacitor, Case A. Analog Devices, upon request. - C30 U1 HmC952Alp5Ge power Amplifier pCB 600-00163-00 evaluation pCB [1] reference this number when ordering complete evaluation pCB [2] Circuit Board material: rogers 4350 or Arlon fr4 For price, delivery, and to place orders: Analog Devices, Inc., One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106 Phone: 781-329-4700 • Order online at www.analog.com
9
Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Output IP3 vs. Vdd @ Pout = 18 dBm Tone Power Compression @ 4 GHz Power Compression @ 10 GHz Power Compression @ 20 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Reverse Isolation vs Temperature Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
