Datasheet HMC952ALP5GE (Analog Devices)
DescriptionGaAs pHEMT MMIC 2 Watt POWER AMPLIFIER WITH POWER DETECTOR 8 - 14 GHz
Pages / Page10 / 1 — HMC952ALP5GE. GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER. WITH POWER DETECTOR …
File Format / SizePDF / 844 Kb
HMC952ALP5GE. GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER. WITH POWER DETECTOR 8 - 14 GHz. Typical Applications. Features
Datasheet HMC952ALP5GE Analog Devices
HMC952ALP5GE
v03.0418
GaAs pHEMT MMIC 2 Watt POWER AMPLIFIER WITH POWER DETECTOR 8 - 14 GHz Typical Applications Features
The HmC952Alp5Ge is ideal for: +35 dBm psat @ 26% pAe T • point-to-point radios High p1dB output power: +34 dBm m s • point-to-multi-point radios High Gain: 32 dB • sATCom High output ip3: +43 dBm r - supply Voltage: Vdd = +6V @ 1400 mA e 50 ohm matched input/output w o p
The HmC952Alp5Ge is a four-stage GaAs pHemT r & mmiC medium power Amplifier with a temperature A e compensated on-chip power detector which operates between 8 and 14 GHz. The amplifier provides 32 dB of gain and +34.5 dBm of saturated output lin power at 26% pAe from a +6V supply. with up to +43 dBm ip3 the HmC952Alp5Ge is ideal for linear s - applications such as point-to-point and point-to-multi- r point radios or sATCom applications demanding ie +34.5dBm of efficient saturated output power. The rf i/os are internal y matched to 50 ohms. lif p m A
Electrical Specifications, T = +25° C, Vdd1, Vdd2, Vdd3, Vdd4 = +6V, Idd = 1400 mA [1] A
parameter min. Typ. max. min Typ max min. Typ. max. Units frequency range 8 - 9 9 - 13 13 - 14 GHz Gain 28.5 31 30 32 28 30.5 dB Gain Variation over Temperature 0.02 0.02 0.02 dB/ °C input return loss 17 17 24 dB output return loss 15 13 14 dB output power for 1 dB Compression (p1dB) 31 33 31 33 32 34 dBm saturated output power (psat) 34.5 35 35 dBm output Third order intercept (ip3)
[2]
43 43 43 dBm Total supply Current 1400 1400 1400 mA [1] Adjust Vgg between -2 to 0V to achieve idd = 1400 mA typical. [2] measurement taken at pout / tone = +20 dBm. Information furnished by Analog Devices is believed to be accurate and reliable. However, no For price, delivery, and to place orders: Analog Devices, Inc., responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106
1
rights of third parties that may result from its use. Specifications subject to change without notice. No Phone: 781-329-4700 • Order online at www.analog.com license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Trademarks and registered trademarks are the property of their respective owners. Application Support: Phone: 1-800-ANALOG-D Document Outline Typical Applications Features Functional Diagram General Description Electrical Specifications Performance Characteristics Gain & Return Loss Gain vs. Temperature Input Return Loss vs. Temperature Output Return Loss vs. Temperature Low Frequency Gain & Return Loss Noise Figure vs. Frequency P1dB vs. Temperature Psat vs. Temperature P1dB vs. Vdd Psat vs. Vdd Output IP3 vs. Temperature @ Pout = 18 dBm Tone Output IP3 vs. Vdd @ Pout = 18 dBm Tone Power Compression @ 4 GHz Power Compression @ 10 GHz Power Compression @ 20 GHz Power Dissipation Second Harmonics vs. Temperature @ Pout = 18 dBm Second Harmonics vs. Vdd @ Pout = 18 dBm Second Harmonics vs. Pout Reverse Isolation vs Temperature Absolute Maximum Ratings Typical Supply Current vs. Vdd Outline Drawing Die Packaging Information Pad Descriptions Assembly Diagram Application Circuit
